Old 24-11-11, 05:14 PM   #1
Destruktor77
Default Have I fried my Charging System?
2000 SV650 done about 18,000 miles.
The original Gel Battery that was in when I bought the bike was totally wasted, we tried charging it, jumping and bumping but never got the bike to start so that went.
But I needed to use the bike there was no other way to get to college. So I used a spare Ducati 998R Battery my dad had, was 12v as well so thought if it works I can use the bike for a couple of days.
So fully charged that battery, it lasted about half a week before I was bump starting the bike again. Got so flat that the bike wasn't running properly so back on the charger overnight. And everynight for about 2 weeks.
Finally my new MotoBatt battery comes down, in it goes and everythings dandy for about half a week with night riding this time so definitely better than the Duc batt. With the lights the battery goes down like no ones business but with them turned off I can ride for at least a week.
So is it most likely I've fried the charging system?
Old 24-11-11, 06:40 PM   #2
timwilky
timwilky's Avatar
Default Re: Have I fried my Charging System?
The charging system is a well known weak point on the SV.
Have a look at http://www.electrosport.com/media/pd...ng-diagram.pdf
Not Grumpy, opinionated.
Old 24-11-11, 09:28 PM   #3
Biker Biggles
Biker Biggles's Avatar
You need a multimeter to check the ststem.A cheap one will do.What you dont want to do is keep putting batteries in it if it is fecking them.Thats expensive at £50 a time.The "original gel battery" wasnt original though as they dont have gel as standard.
Old 24-11-11, 10:17 PM   #4
monkey
Depending on how far you've been riding the bike before manually re-charging the battery it may not be charging at all which could be an easy fix.
As the post above says you need a tester. A Haynes would be handy too.
Charging system failure - maybe. Monty SV Talk, Tuning & Tweaking 8 26-06-10 11:12 AM
Charging system underperforming at idle. Dave20046 SV Talk, Tuning & Tweaking 12 20-01-10 06:40 PM
Charging system question the_lone_wolf Bikes - Talk & Issues 25 31-10-09 07:08 AM
Charging System checking philb SV Talk, Tuning & Tweaking 10 11-06-05 10:29 AM
WTH is going on with this charging system? I know...discusse scarredpelt SV Talk, Tuning & Tweaking 12 01-04-05 01:18 AM
