Old 09-12-11, 08:33 PM   #1
Dunn-y
Default Carb drain or Stabil?
I'm not sure what is the best thing to do. Drain the Carbs by disconnecting the fuel lines and running it dry or putting some fuel stabilizer in the tank and running that through the Carbs.
I will be back on the bike as soon as the ice has gone so probably early Feb.
Old 09-12-11, 11:46 PM   #2
-Ralph-
Default Re: Carb drain or Stabil?
Exposure to the air degrades fuel. Fuel kept in a sealed container will last years. Hold your bike upright and top it right to the brim with fuel. Close your fuel tap and drain your carb bowls. So long as everything else is still good (battery, etc), open your fuel tap in February and it'll fire first time.
I've used Stabil but only in bikes that were off the road for an indefinite about of time, but you don't need fuel stabiliser between now and February.
BTW, does the curvy not have a drain screw on the carbs?
Old 10-12-11, 12:35 AM   #3
Dunn-y
They do but apparently it's a right PITA to get to plus the Curvy doesn't have a fuel tap so I can't stop the fuel flow unless I pull the fuel lines from the Carbs or Tank, not sure which end is best if it makes any difference.
Old 10-12-11, 01:07 AM   #4
-Ralph-
Needs someone that knows the curvy then.
Old 10-12-11, 09:42 AM   #5
NTECUK
NTECUK's Avatar
the carbs are a pain to get to.
Pop in to the local mower shop and get some
Briggs & Stratton Fresh Start Fuel Stabilizer Plus
Old 10-12-11, 03:26 PM   #6
You don't need stabiliser for a couple of months.
Easiest way to stop flow is to remove vacuum line to tap then run it until it dies. (block line to carb or it will pop and fart a lot)
Wanted: Clocks for carb model naked + headlight and carb. Gazdaman Stuff Wanted 2 17-03-10 03:50 PM
how to drain the fuel? Surfjayce Bikes - Talk & Issues 5 24-01-10 02:52 PM
pipes going to carb to carb sv650nutter149 SV Talk, Tuning & Tweaking 3 07-09-08 10:16 PM
how to drain the tank? lancasterlad SV Talk, Tuning & Tweaking 5 26-09-07 09:06 AM
Carb Drain after stutter Tony_BLY SV Talk, Tuning & Tweaking 3 06-10-06 12:39 PM
