Old 15-12-11, 10:33 PM   #1
XmisterIS
Default K&N Filter - need to re-jet?
I'm thinking of getting a washable K&N air filter to replace the stock one because I think it will be cheaper in the long run.
I'm not intending to take out the airbox, just get a standard K&N that fits in place of the stock filter; one of these, to be precise: http://www.knfilters.co.uk/search/pr...x?Prod=SU-6503
Will I need to re-jet?
Old 16-12-11, 08:01 AM   #2
MJC-DEV
MJC-DEV's Avatar
Default Re: K&N Filter - need to re-jet?
Not on a K7 as it's fuel injected!
MJC-DEV is offline   Reply With Quote
Old 16-12-11, 08:49 AM   #3
Badeye
I was gonna get a K&N air filter to replace the stock one but i read a few thread on here saying the K&N air filters for the SV make it worse and that stock are better. I ended up getting a stock air filter to be on the safe side.
Old 16-12-11, 09:02 AM   #4
MJC-DEV
MJC-DEV's Avatar
At the risk of getting flamed but personally I would not ever get a K&N filter for normal road use as they are less effective at filtering than the standard one. In my opinion, for me.
Old 16-12-11, 10:53 AM   #5
DJ123
DJ123's Avatar
How can you quote it to be 'less effective at filtering' as an opinion, surely its factual whether it filters better or worse than the standard filter . . .
the standard filter is as good as a K and N filter, the k and n does give a better induction noise though. I have one on my bike, because it had one when i bought it.
Depending on how long you are going to keep the bike for it can be cheaper. The K and N recharge kit is £15, and the filter only needs charging as often as you would change the standard filter. IIRc the standard filter is £20 or so.
BMW F800ST
Old 16-12-11, 11:11 AM   #6
XmisterIS
He he!
Well, I'll give the K&N a go and see how it does go ...
I can always get a replacement stock one if I don't like the K&N.
Air Filter & Oil Filter from TL1000R fit SV650? AkiraSV SV Talk, Tuning & Tweaking 3 04-08-11 05:19 PM
Spark Plugs, oil filter, Air Filter....Curvy 21QUEST For Sale - SV's and SV related items 2 14-01-10 10:04 PM
k and n air filter Quiff Wichard SV Talk, Tuning & Tweaking 6 05-05-06 08:42 PM
oil, filter and air filter change doe SV Talk, Tuning & Tweaking 10 17-04-06 01:29 PM
To filter or not to Filter.....are you feeling lucky? Magoo Bikes - Talk & Issues 40 02-12-04 05:17 PM
