Old 18-12-11, 02:58 PM   #1
jimathyy
Default Electrical and starting problems.
Following on from the many issue i have had with the bike, in essence, having owned for 8 months, only had running for 1-2 out of that. Depressed.
Anyhoo, had issue with electrics, assumed was poor connection from reg/rec as wire was loose, so taken off, put on new connector and charged battery.
No start.
(a history of poor running / missfire)
Got running, took out (in the rain) and it developed same issue. As light were on, i feel that the battery has died. Now this can only be buggered battery / reg/rec as far as i can see, as had no issues in recent weeks. Have, however left standing for most of the summer.
Today's problem.
Couldn't start her, so connected to car (off). Engine turns, but only occasional firing. HOWEVER, most of the firing is more like a loud bang, and not a "starting" sound. Occasionally sends bang the "wrong way" out of the carbs to the underside of the tank.
What could cause this? I've tried throwing some fuel straight into carbs, nothing. it just won't catch to go.....
Tried some carb cleaner, and some starting stuff from halfords, but still no joy. I have spark and fuel at both cylinders, and am now a bit lost as to where to look.
PLEASE HELP, I'M GOING MAD!!
Old 19-12-11, 09:48 AM   #2
Geodude
Geodude's Avatar
Default Re: Electrical and starting problems.
If you have a multimeter at hand it might be worth giving this electrical fault finder a try. Not sure about the banging from the carbs but have a free bump for your question
Old 19-12-11, 11:25 AM   #3
Serdna
I don't know about your previous problems but maybe you need new spark plugs. Going out in the rain can throw water on the front plug causing the bike to really missfire, running just on 1 cylinder. When i took mine out the front plug was rusty.
The sparkplug problem can be fixed by fitting a fender extender on the front mud guard.
Good luck!
Old 19-12-11, 11:48 AM   #4
Geese
Didn't TAm have a similar problem?
wasn't it due to some mouldy wire?
Old 19-12-11, 01:28 PM   #5
Taipan
Taipan's Avatar
Doesn't sound dissimilar to water in the tank. On my old curvy SV the tank drain had rotted through and when it rained i'd get water seep into the tank. Might be worth checking your tank drain is okay?
http://forums.sv650.org/showthread.php?t=142806
Old 19-12-11, 03:36 PM   #6
TamSV
TamSV's Avatar
Bloody hell, you've not had much luck mate.
Water in the tank is worth checking if your problems have been linked to wet weather. Costs nowt too, which is a bonus. Worthwhile giving the carbs a good strip and clean if you haven't done so already.
Back-firing through the carbs though? What's the history of the engine? (I think you replaced it didn't you?). Is there a possibility that the timing's been mucked up? Was the replacement motor intact with heads and cam chain tensioners etc all in place?
I seem to remember you've also had a few electrical problems? If you haven't got a multimeter then get one and get systematic checking everything. Don't keep chucking parts at it until you're sure you've got to the bottom of it.
If it was me, I'd be doing the following;
1. If your battery's been run flat a few times or left standing, check it's still holding a charge. If not, get a good un in there.
2. check charging system, leakage etc with multimeter. Check your earths and connections are all nice and clean.
3. strip, clean and set-up the carbs
4. drain some fuel out the tank and make sure there's no water in there
5. check the timing (and while you're in there you might as well measure valve clearances)
6. Put it back together. Start it. Do a celebratory burn-out.
You've chucked enough money at this bike now. All the checks above are free. Keep us updated with your findings from the above and someone might be able to narrow things down for you. I'm sure we'd all like to see you resolve this.
Old 21-12-11, 05:50 PM   #7
jimathyy
Hi guys. Today I have drained fuel, nothing abnormal. New fuel anyway.
Cleaned carbs and opened rear one up, no gunge etc.
Not yet looked at the timing, am assuming it's true cause it was running sweet.
Have tried turning over, nothin but a few loud bangs, but havn't pulled the fuel through yet I think, more attempts tomorrow.
I DID however find a kink in the fuel expansion/overflow line. Maybe, and gopefully the issue!
Battery seems fine, can't do all checks though without it running......
Further updates as and when.
For additional info, this is the 2nd engine, and it came complete and ran well, when it was running. Had nbo end of bloody problems! Aarrgg! The wife is most certainly not happy!
Anythin else I should check before I put mucho effort into cranking her over?
J
Old 29-12-11, 02:47 PM   #8
jimathyy
Today's update......
1. Had a small amount of exposed wire on the main -ive to the battery, so have taped up, melted plastic on exhaust in the past, but it's never cause any issues before.....
2. Had a loose -ive on the thermostat. Put back in place.
3. Ensured all other wiring is in the right place.
4. Ensured that fuel getting to carbs, it is.
5. Double checked battery. Reading 12.7 v as it stands unplugged.
6. Removed spark plugs and cleaned, warmed and wire brushed. Good spark when tested against frame.
7. Went to start with half choke. Nothing.
7.A. Full chock. Nothing.
7.B. No choke. Nothing except 2 backfires.
8. Pulled out some hair.
9. Tried again. Had a fag. Tried AGAIN. Nothing.
10. Came and logged on.......
Any ideas guys? Might have to get to a garage, but don't want this to beat me, and can't really afford the £60/hour labour!!!!!
J
Old 29-12-11, 03:25 PM   #9
muzikill
muzikill's Avatar
When i had a starting problem (injected model) someone suggested smelling into the area where the fuel goes to be ignited if it didnt smell of fuel then to try scooshing some sure start into it and quickly firing the engine up which it did. I ended up having to send the injectors away to be cleaned. Ok so you have the carb sv, but it was this 'thinking out the box' type advice that eventuially resolved my issue.
Old 29-12-11, 03:30 PM   #10
jimathyy
It's defo got fuel in carbs. Is it worth dunking a load of fuel straight in the top? I have some easy start too, but not really too sure how to use it......
Bike not starting, I think it is electrical MONOLITH Bikes - Talk & Issues 6 22-09-11 06:09 PM
Electrical starting problem SVAlex Bikes - Talk & Issues 17 27-05-10 10:48 PM
SV650 electrical starting problem fabz11 Bikes - Talk & Issues 12 05-04-10 12:56 PM
Electrical problems mister c SV Talk, Tuning & Tweaking 3 19-06-07 09:30 PM
Electrical problems asus SV Talk, Tuning & Tweaking 3 22-08-06 01:25 PM
