Old 19-12-11, 05:54 PM   #1
YvenelC
Default Chain fitting?
Recently my chain snapped off my bike, well just the link! Purchasing a new chain and sprocket! Its pretty easy to chain the sprockets and chain is there any adjusting of the chain or anything extra I should know before I install it myself?
Old 19-12-11, 06:11 PM   #2
Default Re: Broken Chain
Do you mean is it easy to install the new chain & sprockets?
You'll need something to rivet the links to join the chain, so you'll need a chain riveter.
Rear sprocket is easy to change, front sprocket you'll need a 32mm socket to undo the nut, as well as not forgetting to bend the locking tab washer back first. Buy a new tab washer as well.
Yes, you'll need to adjust the new chain once you've fit it.
Old 19-12-11, 06:33 PM   #3
YvenelC
Sorry for the typo but yes that's what I meant... to adjust the chain don't need any special tools do I?
Old 19-12-11, 06:38 PM   #4
MJC-DEV
MJC-DEV's Avatar
Maybe the chain broke because you didn't keep it adjusted correctly?
When you fit the chain, use a chain rivet tool to join the ends, then you MUST adjust to the correct tension as per instructions in the handbook or manual.
MJC-DEV is offline   Reply With Quote
Old 19-12-11, 06:42 PM   #5
Spanner to undo the wheel spindle nut. One in the tool kit if you have one.
Allen key to adjust the adjusters if you've got a curvy (99 - 2002)
Spanner for the pointy I think.
But you need to check the wheel alinement's correct after you've adjusted the chain
Here's a how to vid
http://www.ehow.com/video_4956935_ad...cle-chain.html
Old 19-12-11, 07:46 PM   #6
Stonesie
The front sprocket nut will be very tight, you will probably need to wrap the chain back around the sprockets and wire it together then chock the back wheel with some wood to get enough force into the nut to shift it, unless you know someone with an impact gun? I have one and a couple of bursts had the nut off. Don't be tempted to use it to tighten things up though, that's a torque wrench job. The rear sprocket is pretty easy.
If you can't get a chain riveter or just don't fancy doing it yourself then get a split link and get a bike mechanic to swap that for the rivet link, shouldn't cost much, maybe some beer tokens
Old 19-12-11, 10:35 PM   #7
YvenelC
I know this is a stupid question but what's the difference between a rivet link and a split link... I ordered a connecting master link which will connect my chain back together... will I need any other extra accessories?
Old 19-12-11, 10:43 PM   #8
Biker Biggles
Biker Biggles's Avatar
A split link is a temporary connector to allow you to ride somewhere to get the chain rivited properly.They are ok to use permamently on small low powered bikes like 125s as well,but on a big bike you need to use a rivited join or the chain may come apart.Is that what happened on yours?You should also fit new sprockets with a new chain or it will wear out much quicker.
Old 19-12-11, 10:51 PM   #9
TamSV
TamSV's Avatar
Split link - a clip is used to secure the plate.
Rivet link - the plate is pressed on and the hollow ends of the pins are peened over with a special tool (or a couple of hammers).
You want a rivet link for the SV.
Old 20-12-11, 09:59 AM   #10
mikerj
If you've ordered a new chain and sprockets (as you mentioned in your OP) then the new chain will come with a rivet link.
Chain fitting advice? lx_online Bikes - Talk & Issues 4 24-09-11 07:14 PM
Fitting chain and sprockets? SVFreak SV Talk, Tuning & Tweaking 10 16-05-10 05:28 PM
When fitting a new chain... DarrenSV650S Bikes - Talk & Issues 52 15-09-09 07:52 PM
Chain fitting query.. 3MM SELKENT 0 24-12-08 05:44 PM
Chain fitting help pencil shavings SV Talk, Tuning & Tweaking 2 14-10-08 08:58 PM
