Old 21-12-11, 03:29 PM   #1
ricksname
Default Lower fairing fixing kit?
The panels I'm after come with some fittings. Which is wonderful. But I think the kit is incomplete. The photo below shows everything that comes with. Will I manage, or will I need more bits?
http://img.photobucket.com/albums/v6...k/IMAG0650.jpg
Thanks!
Old 21-12-11, 03:49 PM   #2
The Guru
Default Re: Incomplete fixing kit
That photo is in your email account.
Old 21-12-11, 03:53 PM   #3
ricksname
Fixed!
Old 21-12-11, 04:24 PM   #4
Owenski
If these are lower fairings for a pointy then that looks just about right.
Extended frame bolts left and right... Check
lower mounts either side... Check
Rad Mount bolts... Check
Upper Fairing Mount bolts... check.
Outer fairing caps... Check.
Only things looking to be missing are the bolt for the 2nd cap
You're missing about 5 washers with collar for bolts to slip through and tighten against without crushing the fairing. Dont panic just yet though, check the fairings because if they've been fitted once its likley they're still in the holes.
Old 21-12-11, 04:26 PM   #5
Owenski
Oh tell you what you will need if you havnt got it already... copper slip!
The fairings need to come off for just about everything you do, and those bolts love nothing more than the seize right up on you.
Old 21-12-11, 04:41 PM   #6
ricksname
Excellent, thanks for this. As for the caps, can I replace these with some crash bungs?
Old 21-12-11, 04:54 PM   #7
Shellywoozle
Shellywoozle's Avatar
Yes ya can; I have one crash bung the other is missing
Old 21-12-11, 05:08 PM   #8
you are missing the radiator mounting u brackets
Old 21-12-11, 07:33 PM   #9
ricksname
Can I deal without these? Or can they be bodged?
Old 21-12-11, 07:36 PM   #10
Shellywoozle
What they look like, i look in box of tricks
SV650 K3-K7 lower fairing fixing kit Fifteen15 For Sale - SV's and SV related items 8 25-02-13 06:16 PM
wanted lower fairing fixing braket white rider For Sale - SV's and SV related items 1 02-10-09 08:27 AM
Fixing kit sv650s lower fairing natcar Stuff Wanted 2 18-10-07 02:45 PM
Curvy Lower Fairing Fixing Kit Query TheStudent SV Talk, Tuning & Tweaking 1 19-09-07 04:56 PM
HELP on fixing Lower Fairings carlos19679 SV Talk, Tuning & Tweaking 2 09-01-05 08:56 PM
