Not me.
![]() Carol and I stripped Sylvie down today and checked the valve clearance and were delighted to find that every one was within tolerance. Mileage so far is just under 18K and she runs as sweet today, as the day she was made. ![]() Next job is to refill the cooling system, we would have done it this evening but it got late so we retired for dinner. ![]() |
Nicely done
![]() I did the valve clearance check on my GSXR myself earlier this year. Scary while I was doing it but actually not so tough actually! |
Well done but where is the tutorial?
http://www.flickr.com/photos/52990092@N05/ |
It is really very simple.
1, Removed fuel tank. 2, Take off top cover. 3, Ask wife to check clearances while watching what she she does. |
Nice one Rev, when you doing mine
Black naked 1999 sv650 which im trying to keep happy Custom paintwork Saragon Customs Spray painting Electrical fault finding guide and Regulator rectifier test Only a biker knows why a dog sticks his head out of a car window. |
And hows Carol to work her magic if your stood watching with your top cover off
#7 | |
![]() What this means is that if I can can undertake a valve clearance check, any one can, it is nothing to be afraid of and is actually quite simple, especially if you have a loving wife ready to help if you get stuck. By the way Geo, if you want your bike doing, you need to get to Weston and speak nicely to the wife. She is a good sort. ![]() |
The Sick Man
check check and check again before starting
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#9 |
S'fair enough checking but another thing having to replace the shims!.
Well done though ![]()
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
Valve clearances - who & how much? West Yorkshire. | sloppy joe | SV Talk, Tuning & Tweaking | 26 | 31-07-12 09:09 AM |
Valve clearance check? | suzuki madboy | SV Talk, Tuning & Tweaking | 8 | 24-04-11 09:23 AM |
Done a valve clearance check, how do I preceed now? | MrTom | SV Talk, Tuning & Tweaking | 15 | 02-02-10 08:09 PM |
Valve clearance, should I take it? | Old Git | SV Talk, Tuning & Tweaking | 21 | 14-09-09 11:54 AM |
Valve clearance check, any tips? | Interceptor | SV Talk, Tuning & Tweaking | 22 | 03-06-09 11:29 AM |
