Old 28-12-11, 04:47 PM   #1
TommyM
Default DR650 rectifier on SV?
like an idiot i have purchased a 6 wire rectifier regulator, i have the three stator wires my red and black output but then i also have a orange/black cable. Does anyone know what this sixth cable is for or if i can fit this r/r to my curvy sv?
Old 28-12-11, 04:47 PM   #2
TommyM
Default Re: 6 wire dr 650 rs rectifier
i have hunted google but found no info
Old 28-12-11, 05:09 PM   #3
TommyM
Old 29-12-11, 10:04 PM   #4
TommyM
:s clueless?
Old 29-12-11, 10:12 PM   #5
tigersaw
tigersaw's Avatar
From the picture it looks a smaller gauge wire than the rest?
Without being able to see a dr650 wiring diagram I can't comment, but chances are it'll be a feed for a monitor or aux circuit, and not needed in your case.
Do you have a manual for the bike it came from?
Old 29-12-11, 10:59 PM   #6
TommyM
Default Re: DR650 rectifier on SV?
You are correct, the extra wire is smaller than the others, i cannot find a manual and i think some models of this bike actually use a 5 wire. Trust me to end up with this. I thought there were only 5 and 7 wires.
Old 29-12-11, 11:49 PM   #7
BBadger
do not plug it in!!!! it will fry everything as that orange wire goes up into the clocks/ that mess behind the headlight on the oz and us model....never quiet worked out what it did even after studying a wiring diagram for hours.
i believe but dont quote me on this its the same as the dr350 ill check tomorrow for you on wire colours, and if so i bought one from this lot http://www.brooksbarn.co.uk/DR350-RE...ire_ATE4W.aspx
has worked a treat and seems more solid better cooling less heat given off anyways ect.
also pop over here good bunch. http://www.maximum-suzuki.com/forums/index.php
lots of info and tips in the archive.
[edit]
also for some reason with that orange not plugged in it likes to throw out lots and lots and lots of ac...things go bang...quickly not that i would know ofc
Old 29-12-11, 11:56 PM   #8
TommyM
Thanks mate, i think I wont risk putting that anywhere near my bike, as for those who see my thread in essex section its taken enough of a beating already
Old 30-12-11, 12:02 AM   #9
BBadger
i dont think they can take enough of a beating...they just keep on going.
also if you look on that website they have 2 listed under dr650 just need to find the right one.
Old 30-12-11, 07:07 AM   #10
tigersaw
tigersaw's Avatar
Looking at the circuit diagram of a 94/95 DR650, O/B (does your orange wire have a tracer colour in it, same as the black has a white?), is connected to the battery +ve through the ignition switch. That would make it a monitor/feedback loop for the regulator, so leaving it open circuit would make odd things happen.
Suzuki DR650- Anything to watch for? andrewsmith Bikes - Talk & Issues 16 14-10-11 06:06 PM
Dud rectifier :) Ernst SV Talk, Tuning & Tweaking 2 25-06-10 06:21 AM
Its the rectifier i think shortz SV Talk, Tuning & Tweaking 10 27-10-07 06:00 PM
rectifier hovis Stuff Wanted 2 23-09-06 09:25 AM
Suzuki DR650 / Honda SLR650 / BMW F650? TSM Bikes - Talk & Issues 8 28-02-06 09:49 PM
