Old 31-12-11, 07:00 PM   #1
musne
Default Removing the Silencer/muffler of a scorpion exhaust.
Hello all!
I have a quick question and hopefully a quick answer too...
Apart from the better noise that it makes, does removing the silencer/muffler cause any problems or have bad side effects?
I've got an SV650S 08 year with a Scorpion exhaust.
Old 31-12-11, 07:08 PM   #2
SoulKiss
SoulKiss's Avatar
Default Re: Removing the Silencer/muffler of a scorpion exhaust.
Originally Posted by musne View Post
Hello all!
Only bad side effects are you may fall out with your neighbours and the fines if pulled by the police.
Old 31-12-11, 07:58 PM   #3
SV Mad
I've got one and got so used to the baffle out, when it was put back in for the winter (so as not to annoy the neighbours all year) I only lasted a week before I was bored of the muffled sound and pulled it out again.
Old 31-12-11, 08:31 PM   #4
musne
Haha, alright thanks guys. It was worth a check!
I can't believe how quiet a 650cc motorbike can sound with a silencer on! :O Sounds beastly without it though
Old 01-01-12, 12:40 PM   #5
MJC-DEV
MJC-DEV's Avatar
I've got a Scorpion with universal baffle and found that low speed was slightly smoother with no baffle but too loud for everyday use. So I've modified the baffle by cutting off the end plate. This seems to be the best of both worlds with noise above half way between the two extremes and baffle less like low revs performance (admittedly, this could be my imagination but don't think so!)
MJC-DEV is offline   Reply With Quote
Old 01-01-12, 06:28 PM   #6
Have I misunderstood you?
Are you on about taking the whole end can off or just removing the small baffle out the end?
I had a scorpion on mine and sounded awesome, was quieter with baffle in but still sweeter than the mortar launcher that Suzuki fitted.
Old 01-01-12, 06:41 PM   #7
musne
No no, I'm just talking about the piece that you pull out of the tip of the exhaust!
I was just exaggerating how quiet it is with the silencer on, but that was because I was so surprised to hear how loud it was without!
Old 01-01-12, 06:48 PM   #8
Phew that's a relief lol.
I had my baffle in for all of ten minutes, I rode everywhere with it out, I carried it with me under the seat, you could say if pulled you were just trying it out.
Just be sensible, don't get giving the full beans in towns and by people's houses etc, plenty of people run cans without baffles.
I was in a petrol station yesterday and a Harley started up with no cans on at all and was at least double the noise of a scorpion can, how they get away with I'll never know.
Old 17-01-12, 07:22 PM   #9
Urbanfireblade
Performance note.
I had a scorpion can on my Suzuki Bandit 1200, fettled the removeable baffle immensly by welding a dome on the front of the perforated tube to distribute air around it instead of the flat end that the air hits like a brick wall! And also added more holes and re-welded the bracket at a different angle(that the M6 bolt that holds it in the exhaust screws into) so the baffle when fitted in the end can sat dead central in the pipe(look in yours when its off and it'll be ****ed/off-centre!). Even after all that modifying, flat out runs from 60-130+mph, there was no difference in acceleration with it in or out. Tho in first and second gear it wheelied easier so i guess it let the engine rev quicker/easier.
Removing the exhaust headers from a stock exhaust Bayners123 SV Talk, Tuning & Tweaking 3 13-08-11 08:41 PM
Free Standard Sv 'Bazooka' Exhaust Silencer cluffy For Sale - SV's and SV related items 4 26-03-11 11:43 AM
Pointy Exhaust For Sale. (All minus silencer) thefallenangel For Sale - SV's and SV related items 0 30-01-09 11:35 PM
Exhaust (Muffler) gasket/connector Blue_SV650S Stuff Wanted 2 18-09-06 12:02 PM
Scorpion SS, removing baffle cause running problems? red5 SV Talk, Tuning & Tweaking 9 14-08-05 03:11 PM
