Old 03-01-12, 11:41 AM   #1
HoL
Default Fuel light - different q to the normal one, promise!
So I checked the valve clearances on my bike & sure enough although a little intimidating at first it wasn't too bad & I'm glad I did it myself for what I have learnt & money saved
I thought I was being wonderfully methodical about the whole thing noting any connections I'd undone to make sure I got everything back together but it looks like I missed one.
The white connector that goes from the fuel tank to the LHS of the bike just under the fairing / black blanking panels didn't get plugged back in. From what I can tell this is for the fuel light sensor & while the bike still worked as I went for a tootle about it seems to have got a little close to something quite warm & has turned a delightful toasty colour in places.
So now it's plugged back in, the fuel light comes on when I turn the ignition on so can I assume from this that it's not too badly damaged & should still flash when I'm low on fuel OR does it light up anyway whether it's working or not.
I know i'll find out when the tank gets low enough but I want to do a few more things on it & so this may take quite some time.
Plus I'm back in work so I don't mind writing really long posts
Old 03-01-12, 07:17 PM   #2
tj2
tj2's Avatar
Default Re: Fuel light - different q to the normal one, promise!
yes
I like short posts
tj2 is offline   Reply With Quote
Old 03-01-12, 07:53 PM   #3
HoL
Are you a bear?
Old 04-01-12, 08:25 AM   #4
HoL
Was it too obvious where I was going with that one?
How normal is it for the SV to stink of fuel after a ride? hongman SV Talk, Tuning & Tweaking 17 27-02-11 10:26 PM
Fuel light and Oil Light both came on at once. jcalhoun SV Talk, Tuning & Tweaking 3 08-06-10 07:23 PM
Fuel light Geodude SV Talk, Tuning & Tweaking 15 22-09-09 08:24 PM
gas light?(that'll be fuel warning light) Spanish Fly SV Talk, Tuning & Tweaking 9 08-06-07 05:45 PM
Replacement fuel light / fuel tap riktherider SV Talk, Tuning & Tweaking 7 14-05-07 06:41 PM
