Old 04-01-12, 10:27 PM   #1
Icanopit
Default Vehicle MOTs 2012
Not sure whether many have picked up on the "new changes" to vehicle MOTs 2012, the following IS worth a read through.
http://www.theaa.com/motoring_advice...nges-2012.html
In particular dash warning lights now become a fail issue and not an advisory i.e airbag/seat belt, plus others/etc
Old 04-01-12, 10:36 PM   #2
DJFridge
Default Re: Vehicle MOTs 2012
Had the Fiesta MOT'd today. Only catch was one indicator bulb needed replacing. Broken? No, "wrong colour"! It's one of these bloomin' painted bulbs and the paint had deteriorated so it wasn't orange enough any more. It was so much easier before orange indicator lenses became uncool.
(walks away grumbling about the price of everything and young people today....)
Old 04-01-12, 10:39 PM   #3
-Ralph-
They kept it fairly sensible at least, not going to fail cars for a management information light telling you a sensor you don't even need is not even working. Depending on the criteria for 'fitted properly', I bet a few folk with home fitted towbars are going to get failures though!
Old 04-01-12, 10:46 PM   #4
tigersaw
tigersaw's Avatar
Vehicles fitted with aftermarket HID systems must also be fitted with properly working washer and levelling systems.
Pleased about that.
I assume 'vehicles' includes bikes
Old 04-01-12, 10:55 PM   #5
NTECUK
NTECUK's Avatar
Pleased about that.
OK WERE DID YOU GET THAT FROM?
Have you read the official manual?
RfR is
A headlamp levelling or cleaning device inoperative or otherwise obviously defective,
iF ITS NOT FITTED HOW CAN IT BE IN OP????
http://www.motinfo.gov.uk/htdocs/m4s01000701.htm
Old 04-01-12, 11:09 PM   #6
EssexDave
*HID headlights can cause dazzle if they are dirty or aimed too high so car manufacturers must fit headlamp cleaning and levelling systems. A car will fail if a mandatory headlamp cleaning or levelling system is missing, doesn't work or is obviously defective.
In all fairness this is slightly ambiguous...
*From link on AA's website about the CHANGES that are coming in (albeit I haven't read the whole thing properly)
Old 04-01-12, 11:11 PM   #7
tigersaw
tigersaw's Avatar
No I havn't read the official manual.
'Vehicles fitted with aftermarket HID systems must also be fitted with properly working washer and levelling systems.'
Is a statement. I'm hoping it means that just what it says, and the word vehicles includes bikes.
Old 04-01-12, 11:24 PM   #8
muzikill
muzikill's Avatar
Theres a heck of a lot of cars with Hid and im forever flashing them thinking they have the full beam on. Pretty chuffed about this rule now. As its proved that every time I get dazzled by these cars at night theyve been bulb replacements rather than standard to the vehicle. It'll take a year or so for these to dissapear from the roads. I just wish the police would enforce the people who constantly have the fog lights on.
Old 04-01-12, 11:26 PM   #9
They'll just swap the bulbs over for MOT time
Old 04-01-12, 11:27 PM   #10
Vehicles fitted with HID's should have self leveling suspension systems (go through the bump not over it so to speak), so that why they're limited to high end production luxury saloons and rolls etc... as standard.
MOTs Fizzy Fish Bikes - Talk & Issues 13 26-09-09 03:28 PM
So this SORN thing, MOTs etc timwilky Idle Banter 3 12-05-09 12:13 PM
Plate Sizes & MOTs Demonz Bikes - Talk & Issues 4 08-05-09 05:41 AM
Manchester MOTs gettin2dizzy Pennine Massive 8 28-04-09 10:31 PM
MOTs in Sunny Essex dissuade The Essex Lounge 5 29-07-08 02:01 PM
