Old 05-01-12, 10:50 PM   #1
joshwalker094
joshwalker094's Avatar
Default Best brake lines?
Well i want to upgrade the brake lines on the bike. Its an SK6 so 2006 model, and so whats the best option really ?
i have found these on ebay : http://www.ebay.co.uk/itm/HEL-Brake-...item20c0e88046
are these good?
Old 05-01-12, 11:27 PM   #2
TheRamJam
TheRamJam's Avatar
Default Re: Brake lines
I have HEL lines on the GSXR. They are good quality and come in a range of colours and they are not overly expensive!
Previous: Suzuki SV650S K9 - Sold
Suzuki GSXR1000 K8 - Wrote Aff
Honda Fireblade RR-9 - Sold
Yamaha MT 10 - Sold
Current Bike: Aprilia Tuono V4 Factory
TheRamJam is offline   Reply With Quote
Old 05-01-12, 11:31 PM   #3
joshwalker094
cheers ramjam, would you say the ones in the link above are the right ones for my bike ?
Old 05-01-12, 11:43 PM   #4
Joe Marcon
i ordered some HEL braided lines . should come soon . i got mine from wemoto.com
heard there very good
Old 05-01-12, 11:45 PM   #5
Joe Marcon
http://www.wemoto.com/bikes/Suzuki/SV_650_SK6/06/
very pricy on there . but mine were cheaper as urs is a higher spec bike.
Old 05-01-12, 11:57 PM   #6
TamSV
TamSV's Avatar
The lines in your ebay link are for the naked SV so would be a bit longer than you need for your S model.
They're also the "race" setup so would be a different layout to the stock setup - i.e. 2 lines connected to the master cylinder with one going to each caliper.
Old 05-01-12, 11:59 PM   #7
Joe Marcon
i think i ordered the race set up :/
http://www.wemoto.com/bikes/Suzuki/S...-_Race_Set-Up/
Old 06-01-12, 12:21 AM   #8
joshwalker094
With them being longer would it matter too much? The rear would be the right size though. And the race is supposed to be better, and better than having the lines on fender.
And thanks for the replies.
Josh
Sent from my GT540 using Tapatalk
RIP Reeder
JOSH WALKERRRRRRRRRRRR
Old 06-01-12, 12:52 AM   #9
TamSV
TamSV's Avatar
Josh
IME, it's difficult to take up extra length in braided lines and keep it both safe (i.e not fouling on anything when you turn the bars) and looking tidy. Otherwise, they would of course work the same.
Personally, I'd stick to the right length for the bike. I had SV braided lines on my GSXR front end and, although the difference in length was very little it made a big difference to the routing from the M/C and looked a bit odd. That may not bother you of course.
Most people (including me) go for the race setup because it's cheaper. I'm not sure it's "better". I'll happily be corrected, but I can't see any functional difference between race and stock setup.
Old 06-01-12, 12:09 PM   #10
muzikill
muzikill's Avatar
speaking of this, would this be considered as a mod to tell you insurance?
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads sv-racing-parts SV Talk, Tuning & Tweaking 42 15-09-11 10:27 PM
Brake LInes vardypeeps SV Talk, Tuning & Tweaking 6 02-10-08 04:38 PM
HEL Brake Lines buckstone SV Talk, Tuning & Tweaking 1 20-05-08 04:24 AM
SV brake lines svrash For Sale - SV's and SV related items 1 27-02-06 10:42 PM
Brake lines Barty_b0y SV Talk, Tuning & Tweaking 4 24-02-05 05:32 PM
