Old 05-01-12, 11:34 PM   #1
Joe Marcon
Default What DID chain and sprockets to fit my bike?
Not sure which is the right sprocket in DID range . Seen theres an O ring and X ring . Not sure . What will fit my sv650s 2001 ? Thanks
Old 06-01-12, 09:52 AM   #2
Default Re: What DID chain and sprockets to fit my bike?
Why DID?
Sprockets are just sprockets, no O rings on them at all. Get steel ones, preferably JT brand ones.
As for chain, you want 525 chain, 108 links. Personally I think X ring is gimmick and recommend a heavy duty O ring chain.
Old 06-01-12, 11:14 AM   #3
Joe Marcon
Why DID?
would i be ok getting this
http://www.ebay.co.uk/itm/SV650-S-99...item335d507b3d
Old 06-01-12, 11:54 AM   #4
Why DID?
Cost YC
It works out to about £20 for the Sprockets, based on the list price for the Chain (the chains about £86 on wemoto).
I'm with you on the O ring and X ring being a gimmick, both do the same job wear at a similar rate.
Originally Posted by Joe Marcon View Post
That set would work, also you'll need the washer and probably the nut depending on how badly corroded they are.
Old 06-01-12, 12:00 PM   #5
VX is not that good. Spend a bit more and get VM or ZVM if you do miles.
Old 06-01-12, 01:35 PM   #6
I'm going to check the new I've got as I can think what the chain is
Old 06-01-12, 01:37 PM   #7
Joe Marcon
Cost YC
yes i do . how much and can you get me link for my bike on this nut ?
Old 06-01-12, 01:40 PM   #8
Nut 09159-20004 £12.06
Washer 09167-25019 £1.82
Robinsons foundry 01227 454366
Old 06-01-12, 01:47 PM   #9
Joe Marcon
thanks alot chris
Old 06-01-12, 01:49 PM   #10
Just as a side note with the nut and washer, if it isn't in stock its about 3 days to order in normally
Can anyone help me fit chain and sprockets? sam anon Thames Valley 2 20-10-11 12:36 PM
New chain and sprockets CDM SV Talk, Tuning & Tweaking 20 05-07-07 11:25 AM
Chain and sprockets imaleon Bikes - Talk & Issues 1 06-03-07 09:02 PM
Chain and Sprockets GSXR Carlos SV Talk, Tuning & Tweaking 59 15-04-06 07:00 PM
Restricted Bike, Chain and Sprockets UlsterSV SV Talk, Tuning & Tweaking 9 14-02-06 10:54 AM
