Old 10-01-12, 10:48 PM   #1
speedyctr
speedyctr's Avatar
Default Speedo on my SK3 stopped working
I was coming home from work when the speedo suddenly stopped working ie it just displays 0mph.
I have checked the manual so will do some checking and poking around probably at the weekend. I have done a search on the forum but was just wondering if anyone can tell me if its common and what usually causes it and how to fix/prevent it. Possibly speedo drive??
speedyctr is offline   Reply With Quote
Old 10-01-12, 10:53 PM   #2
tom-k6
Default Re: Speedo on my SK3 stopped working
ive heard alot about rotors breaking, you had the front wheel out recently??
Old 10-01-12, 11:07 PM   #3
DJ123
DJ123's Avatar
this. Take front wheel off and check that the rotor is still in one piece
BMW F800ST
Old 11-01-12, 01:14 PM   #4
ulsy
this happened to my sk3 a few months ago. the rotor was broken. I glued it back together with superglue and it has been fine since.
Old 11-01-12, 07:11 PM   #5
AkiraSV
Another bump for checking the rotor. They're quite fragile. Get your front wheel out and it should be immediately obvious whether it's damaged or not.
Old 11-01-12, 10:29 PM   #6
Jayneflakes
Jayneflakes's Avatar
Exactly the same on mine. Rota broke, glued back together with epoxy, worked fine again. The magnet is very soft and easy to damage.
Jayne you're a Pussy Magnet
Old 12-01-12, 08:16 AM   #7
Take out the drive and check the rotor.
If rotor is ok, test the drive as the do fail from time to time. The test takes a basic testing rig and a multimeter, voltage (dc) should be rig supply with the wheel pulsing drive or zero.
Old 16-01-12, 08:58 AM   #8
speedyctr
speedyctr's Avatar
Thanks for all of your replies . I have not got round to having a look yet but fingers crossed I'm getting an Abba stand next week for my birthday so it should make it alot easier for me....
Old 26-01-12, 10:35 PM   #9
speedyctr
speedyctr's Avatar
I don't think I'll be glueing this rotor back together. It just looks as though it has disintergrated. It doesnt seem to want to come out either, I might have to chisel it out.
Old 27-01-12, 11:14 AM   #10
blue curvy jester
Have you had a tyre change recently as this is a common place for the rotor to be fecked
Speedo, rev tacho, lcd displays all stopped working this morning Paul the 6th Bikes - Talk & Issues 5 13-07-10 05:20 PM
Speedo Stopped Working Apophes SV Talk, Tuning & Tweaking 8 31-12-07 04:28 PM
Scottoiler has stopped working?? MarkyBoy SV Talk, Tuning & Tweaking 8 03-10-06 12:43 PM
speedo stopped working weazelz SV Talk, Tuning & Tweaking 11 07-09-06 04:44 PM
My Horn Has Stopped Working PoRk ChOp SV Talk, Tuning & Tweaking 7 27-03-06 08:56 AM
