Old 13-01-12, 11:01 AM   #1
bikeramy
Default Aftermarket Indicators flashing too quick - which relay?
Which relay do i need to get, 7 pin? I see them on Ebay but i am unsure which is correct fit for a Suzuki sv650s pointy.
x
Old 13-01-12, 11:34 AM   #2
MJC-DEV
MJC-DEV's Avatar
Default Re: Aftermarket Indicators flashing too quick - which relay?
Suzuki 7 pin LED indicator relay including side stand cut-out circuit such as
http://www.ebay.co.uk/itm/SUZUKI-7-P...item5d30c437ab
MJC-DEV is offline   Reply With Quote
Old 13-01-12, 11:41 AM   #3
dkid
+1
Followed the same advice, worked a treat for me. No need to wire in the resistors that were supplied with my led indicators (oxford saturn).
Got the correct flash rate inc hazards.
Old 13-01-12, 11:50 AM   #4
bikeramy
Just bought, thank you guys !
Old 01-03-12, 11:20 AM   #5
Djgary
thanks for the info, unfortunately for some reason the guy selling these on the link supplied no longer stocks them, however another supplier is on the following link. ordered mine today, cheaper than the halfords fix and no wiring to chop so happy days.
http://www.ebay.co.uk/itm/LED-flashe...ht_1873wt_1163
Old 10-10-12, 03:56 PM   #6
bikermike
Hi
will this fit curvy models?
Old 04-05-13, 07:40 PM   #7
sopeluk
just wanted to say thanks
Old 10-05-13, 07:01 PM   #8
DJFridge
Originally Posted by bikermike View Post
Hi
Yes, same relay. I bought a BikeIt one from sportsbikeshop which did the trick. Had two off eBay which failed
Indicators flashing too fast... Gnome SV Talk, Tuning & Tweaking 17 14-02-18 06:50 PM
Indicators not fully flashing? Philip663 SV Talk, Tuning & Tweaking 0 09-12-10 04:59 PM
LED indicators flashing fast. SuzukiNess SV Talk, Tuning & Tweaking 27 08-03-10 07:14 PM
Indicators Flashing Fast Mr_Chin SV Talk, Tuning & Tweaking 6 28-08-09 04:41 AM
indicators flashing problem mxm35948 Bikes - Talk & Issues 13 05-09-07 10:34 PM
