Old 14-01-12, 11:49 AM   #1
thedarkomen
Default Alternative calipers?
i just wanted to know what brakes i could put on a sv650 k8 because originals are ****
Old 14-01-12, 12:10 PM   #2
Default Re: upgrading brakes
Much cheaper option is to:
- Strip and clean them
- Replace all the seals and pistions as required (do all the seals if they need it)
- Change the pads for something with an HH compound (GG is good if you do a lot of commuting)
- Change the rubber OEM hoses for quality aftermarket braided lines (Goodridge, Hel etc..)
To swap calipers its a full front end change. Suzuki calipers are good but are a git for hoovering up all the crap that lays before them. I clean mine every 6 months and service them when they've seized on from lack of use
Old 14-01-12, 01:00 PM   #3
Default Re: Alternative calipers?
Originally Posted by thedarkomen View Post
originals are ****
They're plenty good enough if they're working properly.
Nothing else bolts straight on, adaptors would be needed and to put it mildly they have a chequered record of fitment.
Old 14-01-12, 04:24 PM   #4
mikerj
Ensure caliper pistons are not seized (common problem) and fit some decent pads. They are not up to modern superbike standards but they are perfectly ok when working properly.
The only caliper that I know for sure bolts straight on is the one from a GPZ500 (since I fitted an SV caliper to my GPZ!) but that would be a considerable backward step!
Alternative Front End? Nick_69 SV Talk, Tuning & Tweaking 5 22-07-09 08:31 AM
Alternative brake calipers? echomadman SV Talk, Tuning & Tweaking 4 17-05-08 09:55 PM
Bike alternative. Pedrosa Bikes - Talk & Issues 111 05-12-07 12:40 PM
Alternative Zen Stingo Idle Banter 0 26-09-06 11:22 AM
Anyone fit alternative calipers to standard forks/discs? davros SV Talk, Tuning & Tweaking 6 18-03-05 07:29 PM
