Old 17-01-12, 08:33 PM   #1
swifty09
Default Sv 650 speedo drive cable needed for 2000 model
Does any one have one for sale maybe from an ex track bike or just one knocking about as mine has just started playing up
Old 17-01-12, 09:01 PM   #2
Default Re: Sv 650 speedo drive cable needed for 2000 model
Whats the drive doing?
Old 17-01-12, 09:24 PM   #3
swifty09
Was on ride home tonight and the speedo went from 70 on the motor way of corse to 0 the 50 to 0 the 60,70,60 then fixed it's self just lefties tank up to see if connectors are together which they are this has never happend before ?
Old 17-01-12, 09:29 PM   #4
You need to clean the contacts on the connectors then test the drive to see if its at fault
Old 17-01-12, 09:59 PM   #5
swifty09
Do you mean the connectors under the tank for on the wheel sensor I presume it's a sensor any way :/
Old 17-01-12, 10:03 PM   #6
It's more likely the rotor breaking up than the cable. It has also been known for a loose battery connection or other wiring fault to cause the clocks to jump around.
Old 17-01-12, 10:06 PM   #7
The wheel sensor is a hall effect sensor, so if it goes wrong it would be broken circuit or a fully closed circuit sending a constant voltage.
The connector is under the tank and is a clear/ white under the air box near the headstock
Old 17-01-12, 10:15 PM   #8
swifty09
Ye I seen that conector and checked it was clipped together will see how it goes on the way to work in the morning thanks for the help
Old 17-01-12, 10:32 PM   #9
Biker Biggles
Biker Biggles's Avatar
Have you had the front wheel off for any reason recently?If so id suspect the rotor got damaged when putting the wheel back on.Common problem.
Old 18-01-12, 08:15 AM   #10
swifty09
No not touched the front wheel is there a main dealer to price up new part just incase
Pointy model Speedo drive basically Brand New £38 sv650k4 For Sale - SV's and SV related items 15 30-12-11 02:17 AM
k5 speedo drive same as 2000 boo86 SV Talk, Tuning & Tweaking 1 17-06-09 07:40 AM
Speedo Cable Needed tonyfarr Stuff Wanted 0 11-06-09 02:41 PM
has the sv650 99 speedo drive cable . elec hellraiser6661 Bikes - Talk & Issues 3 27-08-05 11:04 AM
