Old 19-01-12, 01:17 AM   #1
ghigo
Default GSXR rear wheel conversion measurements?
hello everyone,
ive had my pointy sk3 for about 4 months now and have decided to go down the gsxr front end, and gsxr wheel route so have subsequently started aquiring parts.
Just got me hands on some 06+ gsxr 600/750 front and rear wheels with everything on them,
was looking at the kits for the rear wheel that people in the states sell however ill be f***ked if im paying £150 quid for some ground down second hand parts, so was wondering has anyone on here got the exact measurements as ive got a machine shop down the road thatl do it for much cheaper.
cheers guys
Old 19-01-12, 01:20 PM   #2
BoostFairy
Default Re: Newish member, gsxr rear wheel conversion measurements
It will never work! (this is rob btw ) and im jelous!
If you can get the dimensions of the spacers let me know and i'll get some made up for you, if no one knows we can always have a go at fitting the wheel and measure every thing up at the same time.
Old 19-01-12, 02:53 PM   #3
BoostFairy
Found this
http://forums.sv650.org/showthread.php?t=133165
Also spoke to Peter Dear and he is happy to machine the spacers you need. I'll give you a bell later but i think it is definitely worth doing your own measurements too.
Rob,
Old 19-01-12, 09:11 PM   #4
ghigo
thanks rob that sounds good,
it seems that we just got to figure out how much to machine off the sproket carrier and the caliper bracket then make some spacers as well
Old 19-01-12, 09:31 PM   #5
BoostFairy
Ye and some sleeve spacers as the gsxr has a thicker spindle, its either drill your swing arm or use the sleeve spacers
Old 19-01-12, 11:14 PM   #6
Robw#70
Default Re: GSXR rear wheel conversion measurements?
or knock the bearings out and use ones with smaller i/d!!
Old 20-01-12, 09:55 AM   #7
musne
GSXR Rear wheels on an SV.
I'm jealous!
Old 20-01-12, 10:52 AM   #8
BoostFairy
Not a bad point at all, might be worth looking through a bearing book!
Old 20-01-12, 11:00 AM   #9
ghigo
thats a good shout robw#70, i wonder if the sv bearing have the same o/d hmmm ill have to do some measuring,
and @ musne , yeah i know cant wait to get it all on and working but im still having trouble deciding which front end to use the radial gsxr one or the k1k2 1000 which some one has offered me complete with everything brakes clip ons mud gaurd yokes its even got the speedo mod as it came off a sv however its 500 and a part of me thinks i could get a radial set up for that, cant decide which looks better radial or k1 with the 6 pots, help needed
Old 20-01-12, 11:06 AM   #10
BoostFairy
Post some pics of each
GSXR Rear Wheel Conversion (pointy) CheGuevara SV Talk, Tuning & Tweaking 19 05-06-16 03:11 PM
gsxr rear wheel conversion mickeymac SV Talk, Tuning & Tweaking 6 26-11-08 07:01 PM
Rear wheel conversion mwr2452 SV Talk, Tuning & Tweaking 29 04-04-08 08:21 AM
