Old 19-01-12, 10:00 PM   #1
EssexDave
Default Touring tool kit.
Scenario: You are touring, you do not know for sure where you will be staying, but you will probably be camping. As such, you don't want to take everything and the kitchen sink just a few essentials should you need to make any modifications or if anything breaks.
What spares and tools would you lot take with you and why.
Old 19-01-12, 10:02 PM   #2
tom-k6
Default Re: Touring tool kit.
the tool kit the bike comes with or equivalent.
hammer.
gaffer tape and WD40.
small single gas burner for tea/cooking beans.
WET WIPES!!!!
pretty much sorted really.
EDIT: spark plugs.
Old 19-01-12, 10:09 PM   #3
Kilted Ginger
As above, the bike tool kit
a multitool,
tape, cableties, wd40
fixerpeg,
puncture repair,
AA or rac cover
Old 19-01-12, 10:40 PM   #4
Bluefish
breakdown recovery card drat kG said it lol
Old 19-01-12, 10:44 PM   #5
Dicky Ticker
Two bits of plastic
1] Credit card
2] AA or RAC
Decent screw drivers,keys and spanners plus pliers or grips-----------------all of which plus more that are under my seat. The all important rubber mallet
OH!---Don't forget chain lube unless you have an oiler
Old 19-01-12, 10:45 PM   #6
EssexDave
Chain lube? What do you get up to on tour...
Old 19-01-12, 10:47 PM   #7
tom-k6
you dont want the chains squeaking as they struggle do you?! it would alert near by people
Old 19-01-12, 10:51 PM   #8
EssexDave
It's okay, last time we stole it whilst he wasn't looking and lubed up about 10 bikes so his plans were foiled..
Old 19-01-12, 10:55 PM   #9
Dicky Ticker
Now you know why I have a rubber mallet for cunning stunts
Old 20-01-12, 08:09 AM   #10
rictus01
rictus01's Avatar
the most important thing is to review your standard bike tool kit, carefully remove the plug spanner, double ended screwdriver, and axle spanner(s) and then once again using great care place the rest of the contents into a suitable container and keep it as far away as possible from you bike, only retaining it at all if you feel you have to inflicted it on any future owners.
I've no idea what you mean by "tour" as that isn't quantifed, however I can go through what I carry on the Speed four.
behind the rear pods.
spare levers (both clutch and front brake), inner cable replacement kit, puncture kit,12x 6" cable ties,24" garden wire, 2" square of wet&dry, 2 X 12" electrical wire, 12" electrical tape*, 24" gaffa tape*, fix a peg.
* wrapped around one of the levers
in the bike tool kit,
Plug spanner, double ended screwdriver,axle spanner(s), 4 allen keys (of the right size for your bike), mole grip multitool, small adjustable, 1/4" sliding T bar, 1/4" extension bar, 8,10,12,13,14mm 1/4" sockets, blade fuses of 10/15 & 30 amp.
Generally that all lives on the bike, for distance work I would normally add the following.
Small pump spray bottle ACF50
Jump leads
full set of allen keys
3/8 socket set ( I have a small teng set about 10"x4"x1")
Torch
small bag of bolts/ nuts & washers (not handfuls obviously, just enough to get out off trouble).
I'm sure theys more, but that's all I can remember for now.
HTH
Cheers Mark.
sv touring two up? badsaboy SV Talk, Tuning & Tweaking 51 04-02-11 12:27 PM
SV Tool Kit/Spark Plug tool svdemon Stuff Wanted 1 17-12-07 12:29 PM
Touring take 2 Endellion Bikes - Talk & Issues 25 30-10-07 11:48 PM
Touring Endellion Bikes - Talk & Issues 26 08-10-07 07:53 PM
Two up touring northdowns Bikes - Talk & Issues 13 14-03-07 11:24 AM
