Old 20-01-12, 10:28 AM   #1
StitchSV
Default Jobs
Hi All
I've a 2005 SVs that's done just over 6k miles now. I've changed the oil, oil filter and air filter but have a list of jobs that I want to do over the next few weeks and I'd appreciate your advice as to whether you'd bother as a chap (biker for 25 years) at work says if it ain't broke, don't touch it!
I'm planning to do:
1. Replace the engine coolant.
2. Replace the spark plugs (don't bother was the advice if all running ok and with my milage)
3. Replace the brake lines with HEL SS ones and obviously renew fluid front and rear (again advised don't touch if all looking ok).
4. Check F and R brakes and pistons (not sure how easy checking if the pistons have seized is).
5. Change tyres as still on the ones that came with the bike (not a job for me obviously).
I'm a fairweather weekend biker and am ok with a spanner but not great!
Any advice much apopreciated as I've come from sports cars and to be honest they were pampered and all work was done at the dealer.
Old 20-01-12, 12:25 PM   #2
TamSV
TamSV's Avatar
Default Re: Jobs
A bit of preventative maintenance is almost always cheaper and safer than waiting until something breaks.
If it was me;
1. I change it at least every 2 years. If this is a new bike and you don't know how old the coolant is, I'd do it now.
2. Probably OK but inspect and decide. I probably change them alot more frequently than necessary but it hardly breaks the bank.
3. SS lines are a worthwhile mod. If the fluid's very old it'll be dark brown but, again, if you don't know how old it is I'd change it. Then you know for sure and you've reset the clock for when it needs done again.
4. Remove the caliper, take out the pads and pump the pistons out a little. Clean them up with water and whatever bike/car cleaner you've got. They should push back into the caliper with thumb pressure - I usually smear a little red rubber grease round them first. If they're hard to shift/rusty/caked with crud then I would strip and rebuild the calipers - you can often save the seals. It's up to you to decide if you're happy to do this work yourself or not.
5. I'd personally prefer to change 7 year old tyres. In any event, many people say the stock fitment weren't that great when new. I've certainly ridden on older tyres when funds dicated but if you're used to playing with quick cars you can probably stretch to new rubber.
Apart from the tyres and brake lines, the rest costs nothing in the grand scheme of things. It's a no brainer.
Old 20-01-12, 12:52 PM   #3
TheRamJam
TheRamJam's Avatar
Default Re: Jobs
+ 1 do Everything Tam has said
Previous: Suzuki SV650S K9 - Sold
Suzuki GSXR1000 K8 - Wrote Aff
Honda Fireblade RR-9 - Sold
Yamaha MT 10 - Sold
Current Bike: Aprilia Tuono V4 Factory
TheRamJam is offline   Reply With Quote
Old 20-01-12, 04:12 PM   #4
StitchSV
Default Re: Jobs
Thanks chaps
jobs to do Quiff Wichard Idle Banter 2 28-03-08 06:00 PM
My many jobs... Grinch Idle Banter 51 29-10-07 08:49 PM
Any jobs?! M65 Idle Banter 2 15-08-06 03:54 PM
Jobs.. didge Idle Banter 58 15-06-06 05:43 PM
jobs! suzsv650 Idle Banter 2 18-05-06 05:08 PM
