Old 22-01-12, 02:04 PM   #1
JustATrick
Default Brake pad change - now binding
I've just swapped the front brake pads on my ZX-6R. I thought it was
a nice easy job, and I even remembered to pump the lever a few times
to get the pads back on the disc. Now the pads seem to be binding - I can
still move the wheel by hand, and I can still wheel the bike around, but it's
hard work. Any ideas how I can fix it?
I pushed the pistons back by hand until they were about flush with the caliper
surface, which was a fair distance as the old pads were quite low. I've checked
the brake fluid reservoir and it's showing at about max, but doesn't look too
full. I even took the reservoir lid off, half expecting to get a shower in brake
fluid, but it seemed fine.
Old 22-01-12, 07:06 PM   #2
victor_meldrew
Default Re: Brake pad change - now binding
New Pads binding on the split pins ?
Old 22-01-12, 07:17 PM   #3
Did you clean the pistons & grease them with some red rubber grease before pushing them back into the caliper?
just make sure the pads aren't binding on the pins or the caliper either
Old 22-01-12, 07:18 PM   #4
rictus01
rictus01's Avatar
indeed, although just changing pads is a relatively simple thing to do, it should also be accompanied by a caliper service or an minimum a clean, the used friction material of the old pads covers most of the components and can lead to compromised operation (sticking), did you clean the previously exposed area of brake piston before forcing back into the body ?
Cheers Mark.
Old 22-01-12, 07:20 PM   #5
sputnik
... and check that the caliper sliders aren't sticking.
Old 22-01-12, 07:49 PM   #6
mikerj
4 pot calipers on a ZX6R, there are no sliders to stick.
Old 22-01-12, 08:27 PM   #7
rictus01
rictus01's Avatar
not to be pedantic or anything, but possibly 6 pots and as said, brake dust buildup can cause sticking within the pad bed (as well as the pistons) making the pad twist on application.
Cheers Mark.
Old 22-01-12, 08:34 PM   #8
TheRamJam
TheRamJam's Avatar
Have a look at the pins to see if there are any slight marks or grooves in them from wear in tear. If there is then its likely that is what's causing the problem. Replace the pins if needed.
With the pads out pump the lever a bit till you can see the pistons and give them a good cleaning with brake cleaner. Again check for any scoring our gouges. grease up and push back in. Hopefully this should sort the problem.
Previous: Suzuki SV650S K9 - Sold
Suzuki GSXR1000 K8 - Wrote Aff
Honda Fireblade RR-9 - Sold
Yamaha MT 10 - Sold
Current Bike: Aprilia Tuono V4 Factory
TheRamJam is offline   Reply With Quote
Old 22-01-12, 08:42 PM   #9
Holdup
Cheers Mark.
6 pots indeed on a A1P
Old 22-01-12, 08:58 PM   #10
dyzio
dyzio's Avatar
Brake cleaner/tooth brush or is there another way?
I think my brake was binding mister c Photos 14 16-11-10 07:27 PM
Front brake binding after drop - help? branny SV Talk, Tuning & Tweaking 8 29-12-08 09:04 PM
Pointy Rear Brake Binding Cleaning glade SV Talk, Tuning & Tweaking 0 12-07-07 09:54 AM
Rear Brake binding 2mths SV Talk, Tuning & Tweaking 5 06-04-07 09:30 PM
brake pad change - top up fluid? branny SV Talk, Tuning & Tweaking 44 20-04-06 10:12 PM
