Old 08-02-12, 12:17 PM   #1
daveyrach
Default Boarding Loft
I am having loft insulation going in and before they come I had to remove all my personal belongings and boarding from the loft.
I have discovered that the boards are laid on top on the cabling for the upstairs lighting circuits which as i understand could cause the wires to eventually break which would be a right PITA. I assume it's OK when I come to relay the boards to just use a chisel to put some small channels in the joists so the boards are not laid directly onto them.
Any advise greatly appreciated.
Old 08-02-12, 12:28 PM   #2
Fallout
Fallout's Avatar
Default Re: Boarding Loft
Can't imagine it'd be a problem, so long as: you keep the channels to the absolute minimum, the wood doesn't split and you don't intend to put a grand piano in the attic. Assuming you're screwing the boarding onto the beams, you're reinforcing them anyway, so any channels would be at the centre of the structure and therefore not under much stress.
Edit: Kind of assuming you'd only be cutting at most 1/10th into the beam though.
MotoGoLoco - You knows it
Fallout Breakbeat (My Music)
Old 08-02-12, 12:30 PM   #3
Kilted Ginger
DOubt you'll be able to relay the boards. if the insulation is being done to new standards it will be significantly higher than your joists.
Mines getting done next month and i fully expect to have to raise the floor level if i want to re floor it.
However technically you are not supposed to chisel joists to run cables any more, supposed to drill through the joist. Sure some mech tech could explain how a hole through a joist weakens it less than a notch out of its side.
Old 08-02-12, 12:37 PM   #4
daveyrach
It would literally be a notch the depth of 1.5mm lighting cable, so next to nothing.
Can you not relay boards over the insulation as my loft is tiny height wise and i don't have the option of raising the floor.
Old 08-02-12, 12:46 PM   #5
Luckypants
Luckypants's Avatar
If the boards squash the insulation, then it loses much of it's efficiency and so becomes rather pointless. There is a reason it is all soft and squishy (hint: it's not so you can nail your loft boards down)
Old 08-02-12, 12:48 PM   #6
Balky001
Balky001's Avatar
I usually go through the middle joists for wires and notches for pipes but when the wiring is already done it's a pain especially if you can't get to one of the ends.
This old article is quite useful giving distances from support. Make sure your water pipes are insulated whilst you are there
http://www.telegraph.co.uk/property/...oorboards.html
SV650SK3 - GSXR600K2 - GSXR750K6 - ZX636RC1H - HD Sportster 1200 - CBR600F 2012 - GSXR1000K7 - Triumph Bonneville T100 2019 - Aprilia Tuono 660
Balky001 is offline   Reply With Quote
Old 08-02-12, 12:56 PM   #7
Wideboy
Evel Knievel
Wideboy's Avatar
On a professional project no I'd drill holes and rewire, on a personal project I'd make a small grove with a gouge or trimmer as obviously its not getting inspected and scrutinised so its my fault if anything happens
05 DRZ400E
RIP hovis
Old 08-02-12, 01:01 PM   #8
daveyrach
I'm not re-wiring, its only actually two cables (for the two front bedroom light fittings that are a problem and only a fraction of the loft is boarded, its a 4 bed house and there's only 12 boards up there just for a little storage, just to give u an idea. May just grove the joists and lay the 12 boards I have back down.
Old 08-02-12, 01:06 PM   #9
Stephen McG
The maximum bending stresses in any beam are at the top and bottom surfaces so cutting a notch out of a beam top will have a bigger effect than drilling a hole in the mid height.
If you did not want to cut the beam, use a chizel and take a piece out of the underside of flooring board.
The main problem I see with either is to ensure that you mark the top face with a warning that live cables underneath.
I also predict (if not already in place) that there will be soon a restriction on running a cable surrounded by insulation. To me it looks a fire risk.
PS when I did mine, I moved the cables to the edges of the boards, cut a small bit out so that cable was not squashed and was visible from above.
It did not come above the finished floor level.
This also gave visual proof that insulation was below.
I use loft for storage and is not a room
Stephen McG. in Glasgow
Old 08-02-12, 01:06 PM   #10
SoulKiss
SoulKiss's Avatar
If doing that - reboarding over the new insulation IF the new insulation is thicker then why bother.
You'll just reduce the efficiency of the insulation to that of the old stuff.
Wiring in a loft light daveyrach Idle Banter 12 11-01-12 10:29 PM
Can I route hot and cold water pipes through my loft? johnnyrod Idle Banter 9 04-08-11 09:11 AM
look in your loft- or your grandparents loft.. £££ Quiff Wichard Idle Banter 15 29-06-11 09:17 PM
Squirrels in my loft.... Scoobs Idle Banter 36 24-03-10 08:59 PM
Loft insulation Richie Idle Banter 9 15-02-08 01:33 PM
