Old 12-02-12, 11:42 AM   #1
daffyduck1962
Default Lowered bike; shorter sidestand needed?
I'm going to buy a lowering kit for my wife's bike. And once the bike is lowered will I have to have a shorter side stand?
Old 12-02-12, 12:36 PM   #2
Default Re: Lowering kit and sidestand
depends on how low you go. but its a good idea as i've already had an SV go over on its side as it was to upright.
Old 12-02-12, 03:51 PM   #3
Red Herring
Red Herring's Avatar
The easy fix is to grind away a little of the stop so that the stand comes down and just goes a bit further, effectively pointing "forward" a bit more. If you return the bike to standard though you will need to buy a new mount, but they are not exactly expensive and it would be easy to get one from someone breaking a bike.
Old 13-02-12, 10:14 AM   #4
Dicky Ticker
Default Re: Lowered bike; shorter sidestand needed?
Cut the ground end off,reduce in size as required and get the end welded back on,perhaps with a bit of tubular metal over the initial weld to strengthen it
Old 13-02-12, 08:34 PM   #5
muddydude
Is it a curvey?if so ive got 25mm dogbones if ur interested very cheap
Old 14-02-12, 12:08 AM   #6
SVmonkey
Following on from muddydude above, I found a lowered curvy seat in amongst my mountain of parts if you're after one? Less padding but might buy another inch if it helps.
Old 15-02-12, 01:23 AM   #7
bikeramy
Just wonder why you are lowering? Is your wife quite short? Only curious cus I'm 5.4 and although I touch the floor with front toes part I don't see it as an issue, after all most the time we're on the rest brake ain't we. Each to ones own of course, just curious how other shorter people deal with this. X
Old 15-02-12, 10:30 AM   #8
Red Herring
He said it's for his wife's bike, not his wife. Maybe he wants to ride it...?
Old 15-02-12, 11:26 AM   #9
bikeramy
Oh good point .
Old 01-03-12, 05:47 PM   #10
emma sfv 650
had my bike lowered by 40mm at the back still to high i am 5.3.
Steering geometry of lowered bike? Pukey SV Talk, Tuning & Tweaking 8 16-07-10 06:20 PM
ABBA stand fitting on lowered bike? Bullwinkle SV Talk, Tuning & Tweaking 11 14-08-06 12:30 AM
Getting the bike lowered. DanAbnormal SV Talk, Tuning & Tweaking 11 08-03-06 10:23 AM
lowered bike -- need to shorten kickstand lilmskitty SV Talk, Tuning & Tweaking 5 23-05-05 07:21 PM
Help!!pic of sidestand switch needed dmc2373 SV Talk, Tuning & Tweaking 1 07-02-05 10:25 AM
