Classic motorcycle mechanics magazine has a great tutorial this month. If youve thought that its hard to do maybe it might help.
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
TPS Adjustment Step-by-Step Pictorial Guide | coombest | SV Talk, Tuning & Tweaking | 402 | 03-04-22 08:54 PM |
step bump | hang man | Idle Banter | 3 | 12-10-08 04:53 PM |
Trying to be green - a step too far | Ed | Idle Banter | 2 | 02-06-08 11:21 PM |
sv650 to a fz1 is it to big of a step up | jans1971 | Bikes - Talk & Issues | 30 | 28-11-07 02:44 PM |
What's the next step? | MaxSuzuki | SV Talk, Tuning & Tweaking | 9 | 10-07-03 10:48 AM |
