Old 18-02-12, 07:21 PM   #1
aaron020873
Default Heavy front end?
i have not been riding my bike much recently but on the last 2 or 3 short trips i have made i have noticed the front end feels heavy at slow speed, by this i mean hard to turn at first then suddenly seems to dip into the corners, it also feels like it pulls to the side a little when braking but again only at slow speed.
I have just been to blow the tyres up and the pressures were 27 in front and 26 in the rear, i know this is too low so i have put them up to 33 front 36 rear. My question though is were the tyre pressures likely to have been the cause of the poor handling or should i also be checking elsewhere?
Old 18-02-12, 07:25 PM   #2
Default Re: Heavy front end
low tyre pressure will make it feel heavy. now you have the correct pressure go out and try again.
Old 18-02-12, 07:28 PM   #3
quik_d
almost definitely, think about it, the tyre is deflated and so spreads out and effectively becomes wider so harder to turn.
Old 19-02-12, 12:49 AM   #4
chrisinflight
+2 was down to the low pressure
SV 650 How Heavy? Red Herring Mini-Twins 50 17-01-08 01:35 PM
Front end chatter on heavy braking - wtf? thor Bikes - Talk & Issues 16 18-05-07 10:18 PM
too heavy for front shocks and brakes? grecian9 SV Talk, Tuning & Tweaking 3 27-09-06 09:40 AM
why? is heavy metal called heavy metal pegasus The Essex Lounge 14 09-06-05 07:26 AM
I'm too heavy - need front fork upgrade SpankyHam SV Talk, Tuning & Tweaking 21 11-05-05 05:18 PM
