So I've gone and fitted an under tray to my bike which requires an aftermarket light. I chose this one from hein gericke as it fitted the gap perfectly. now when going to wire the light up it simply won't work, I've tested for volts on the loom and its got power so I'm slightly baffled. I know with LED indicators you need a resistor to stop it flashing too quickly, could it be a similar issue?
Any advice would be great, Ash |
have you tried swapping the wires round Led's only work one way, unlike bulbs
#3 | |
And check whether the unit works correctly when connected directly to a 12V source, a new non-working item is far from unknown. Resistors are not needed - they're for making the flasher unit work right, not the lights themselves.
well i have tried connecting straight to the battery with no luck, however after calling HG customer services it turns out that the yellow wire is earth and not the black?!?!? Would have been helpful to have this printed on the packaging if not so obvious!! Will try later hopefully it works if not will be taking it back!!
Feel stupid now but assumed that red was live, black earth and yellow for the brakes!! Thanks for your help! Ash |
Yellow would be earth I'd assume, with Red Live, Black switched live?
Isn't yellow/green usually earth anyway?
Aftermarket Tail Light legalities. | W4tto | SV Talk, Tuning & Tweaking | 2 | 16-06-11 03:17 PM |
Rear light not working - help please? | krhall | Bikes - Talk & Issues | 1 | 05-05-11 07:31 PM |
Rear brake light Tail Light, Integrated Indicators | chrismartin | SV Talk, Tuning & Tweaking | 11 | 04-03-10 04:28 PM |
Brake light not working help | adw | SV Talk, Tuning & Tweaking | 11 | 14-11-07 01:41 PM |
clear tail light / stop light Lens for sale | SVTONYB | For Sale - SV's and SV related items | 7 | 20-05-07 04:55 PM |
