Old 27-02-12, 06:49 PM   #1
davidohana
Default Loss of power at high RPM.
hello , im david and i am new et this forum
i have my SV 650 S for a year next month , and i love it !
i have a problam with my bike , in evry gear et any speed when i get to 9200 RPM i am loseing throttle and cant accelerate for a somthing like 2 sec , and then i get my throttle back ,
i was thinking that it might be a problam with the fule "map "
my bike is working er 20 k"m for 1 liter of gas , and it is too high , how can i fix it? .. or what can the problam be if i am wrong ...
Thanks alot David .
Old 27-02-12, 07:53 PM   #2
Biker Biggles
Biker Biggles's Avatar
Default Re: lose of throttle et high RPM
Have tried changing gear a bit sooner?Sounds to me like you are hitting the rev limiter.There is nothing to be gained from revving it out on a SV as the engine delivers peak torque and power lower down the rev range than 9000.
Old 02-03-12, 03:38 PM   #3
ya92
Default Re: Loss of power at high RPM.
my rev limiter comes on at 11,700 RPM and 2500RPM its alot! maybe its the TPS? or sommat with the spark plugs? please help David!
Old 02-03-12, 03:53 PM   #4
2F45T4U
what year?
Old 02-03-12, 03:55 PM   #5
ya92
2009... tell me what you think it is and we will try to fix it... the engine feels like cut off at 9200RPM like spark or fuel problem :/ any gear at full or 3/4 throttle
Old 03-03-12, 07:33 AM   #6
2F45T4U
The fuel map would never change or 'go wrong'
start with the basics I.E plugs, TPS calibration, and try and pull some fault codes. and see if the air filter is black. there might be a coolant or air temp sensor thats gone faulty which could cause the poor fuel consumption.
If you get no where with that. hook up a strobe light to the plugs and tape it to the bars. go for a run and see if the sparks breaking down when its holding back. Might be a duff coil or crank pick up.
its not a complicated F.I system and there are only 2 cylinders, so you should narrow it down fairly quick
Cheers!
Misfiring / Power loss markwilson Bikes - Talk & Issues 8 02-01-10 08:38 PM
Loss of power, now no go at all. jnr-biker SV Talk, Tuning & Tweaking 8 22-11-09 10:50 PM
Power loss!! chris8886 Bikes - Talk & Issues 12 01-12-07 12:56 PM
Power loss? FreshAL SV Talk, Tuning & Tweaking 6 02-03-06 11:18 AM
Loss of power..... Nekkid SV Talk, Tuning & Tweaking 16 21-10-04 05:00 PM
