Old 28-02-12, 08:54 PM   #1
m1tch_1987
Default Alternative rev counter?
Hi all,
I am just wondering what sort of rev counter would work with the SV engine? The engine will be for race only so all I need to know about is the revs, I can get an oil pressure gauge easily put on due to where the oil filter is, so its just the revs I need.
Old 28-02-12, 08:58 PM   #2
tom-k6
Default Re: Rev counter replacment
couldnt you leave the standard clocks on, or you planning on ditching vast majority of electrics?
Old 28-02-12, 09:03 PM   #3
m1tch_1987
The engine won't actually be in the bike, its a carb engine, so won't have an ECU plugged in either, im not sure what usually wires into the OEM clocks?
Old 28-02-12, 09:28 PM   #4
It's a fairly simple setup to the tacho - live, neutral and trigger from a coil.
Old 28-02-12, 09:36 PM   #5
m1tch_1987
Default Re: Alternative rev counter?
I can get a fairly cheap tach, but they are ment for cars, so only go up to about 8k, which isn't really any use lol I have seen that I can make an LED tacho, but in not sure how bright they will be.
rev counter Davies 52 Stuff Wanted 0 03-04-10 11:05 AM
SV Rev Counter jcuff86 SV Talk, Tuning & Tweaking 4 16-04-08 06:56 AM
Counter counter steering - does it exist? thor Bikes - Talk & Issues 30 22-10-07 11:17 AM
Rev counter! Slim666 SV Talk, Tuning & Tweaking 9 26-06-07 01:36 PM
rev counter out jelv SV Talk, Tuning & Tweaking 0 22-12-06 07:15 PM
