Old 09-03-12, 07:41 PM   #1
Default Reg/ Rec failure obvious symptoms?
Evening all
It looks like my bike may have another used a consumable part its Reg Rec.
Whats the obvious signs that its on the way out (before I tear the bike down and start testing)
Also prempting the failure whats bikes run MOSFET units that are simple to plug and play
Thanks in advance
Andy
Old 09-03-12, 09:58 PM   #2
BoostFairy
Default Re: Reg/ Rec failure obvious symptoms
Honda CBR (i forget the year) regulators are mosfet. There are several very good guides dotted around detailing how to make the swap.
One easy symptom may be that your head lights increase in brightness when you rev. Get a multimeter on the battery and see what the voltage is when at idle and when revving.
Make sure you don''t let your battery go dry, your battery (if your reg has lunched its self) is currently acting as a very good buffer, a dud reg can output circa 70v at high RPM, your battery drags this down to acceptable levels in the short term. A friend managed to destroy every electrical component on his bike when his battery went dry.
Rob,
Old 09-03-12, 09:59 PM   #3
BoostFairy
Here you go mate, happy reading
http://www.svrider.com/forum/showthread.php?t=106041
Old 09-03-12, 10:01 PM   #4
Yep its mullered the headlights started that tonight and the reg was warm
Old 09-03-12, 10:03 PM   #5
BoostFairy
You best get reading/spending then
Old 09-03-12, 10:05 PM   #6
missyburd
My SV's reg rec's just been swapped for a CBR600RR one, seems to be doing the job nicely. I wasn't able to have grips on highest setting while headlight was on.
Old 09-03-12, 10:08 PM   #7
Cheers Rob
Confirmed what I thought worked. MYB what you pay for yours?
Old 09-03-12, 10:14 PM   #8
missyburd
Well actually I've nicked it off YC's SV (I stripped the bike's back end myself #proud face#) and let him have the ZZR1400 one i got for £58 off fleabay, they're all around that price unfortunately...
Apparently you can have any of these - and I know this because I wrote it down from mouth of YC other night
'06 onwards YAM FJR
'07 onwards YAM R1
Any year ZZR1400 (FH010)
'06 onwards CBR600RR (FH00
I think that code is to make sure it's not the Shunt model...correct me if that ain't right please, it was a few nights ago when I was told and I've slept since
and many more besides.
Old 09-03-12, 10:19 PM   #9
The beast still lives??
I'll be trying my local breakers tomorrow morning gets a lot of sports bike through (its where my rear shock came from)
Old 10-03-12, 10:59 AM   #10
MYB
You know if his oiliness had to modify the connections for the CBR unit?
Heatstroke - Symptoms and treatment in dogs. Samnooshka Idle Banter 3 04-07-09 11:58 AM
Crash.NET - Stoner 'feels better', wary of symptoms. NewsBot News 0 01-07-09 02:40 PM
Obvious New Item of the Day SoulKiss Idle Banter 7 20-01-09 06:33 PM
Oh dear... Take these symptoms and... northwind SV Talk, Tuning & Tweaking 13 14-07-08 10:37 AM
Haggling if a bike has no obvious flaws... Bear Bikes - Talk & Issues 64 21-11-07 09:04 AM
