11-03-12, 03:45 PM | #1 |
OEM Chain & sprocket set for £100.00
http://www.robinsonsfoundry.co.uk/bu...7000-32820.htm
unfaired btw, weird i didnt know that this would be different for faired/unfaired.
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ), drop it & fix it again! K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. Last edited by muzikill; 11-03-12 at 03:49 PM. |
11-03-12, 03:53 PM | #2 |
Re: OEM Chain & sprocket set for £100.00
yes the rear sprocket and consequently the chain length is bigger on the unfaired
Not Grumpy, opinionated. |
11-03-12, 05:12 PM | #3 |
is it ok to fit N version c+s on faired version (curvy)?? what the difference would be
11-03-12, 05:13 PM | #4 |
Yes it is ok.
Result because of the gear change should be slightly faster acceleration but knock a tad off the top end.
11-03-12, 05:27 PM | #5 |
If its the same as toothing down by 1, then you wont even notice the top end reduction as the SV doesnt rev out in top.
11-03-12, 05:39 PM | #6 |
You might have to chop the chain on a S
12-03-12, 09:19 AM | #7 |
12-03-12, 10:44 AM | #8 |
AFAIK (certainly on mine) the S on standard gearing should not (can not) reach red line in 6th flat out.
12-03-12, 10:45 AM | #9 |
Pity i have a 650s k3, i can get a better set for less, £138 quid for a longer chain & one extra tooth? wtf!
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ), drop it & fix it again! K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
12-03-12, 11:05 AM | #10 |
ah...ballrocks...I just bought new C&S from B&C
Standard front sprocket, bigger rear sprocket, how many more links in chain required? | Holdup | Bikes - Talk & Issues | 6 | 27-02-12 12:40 PM |
Will this Chain and Sprocket set fit? | Chewie | SV Talk, Tuning & Tweaking | 18 | 16-01-10 09:18 AM |
Chain and sprocket | CodeJACK | Hardware | 5 | 18-04-08 01:24 PM |
Sprocket/Chain | Mr. Bob | SV Talk, Tuning & Tweaking | 2 | 03-05-07 08:43 PM |
Chain and sprocket set | scorpion | SV Talk, Tuning & Tweaking | 6 | 03-04-07 08:26 PM |
