Old 12-03-12, 05:47 PM   #1
ian505050
Default My tyre had negative tread after the good weather on Sunday
Now replaced with Michelin Road 2, just home it lasts a little longer than this one did.
ps. i do check my tread depth, this tyre had over 1mm at the start of the day.
Old 12-03-12, 05:51 PM   #2
Red Herring
Red Herring's Avatar
Default Re: My tyre had negative tread after the good weather on Sunday
If you were riding hard enough to take out 1mm+ of tread in a single day from the middle of the tyre you were definitely riding to hard for a tyre in that condition to start with....luck was on your side. Buy a lottery ticket quick!
Old 12-03-12, 06:03 PM   #3
ian505050
My bike requires me to go up and down all five gears to get too and from 70mph. On each gear shift it seems to slip and skip so i recon this is whats worn it out too fast. Also coming into corners i found dropping it in a gear that was a little low locked the rear end up which probably contributed to the fast deterioration.
If worst came to worst at least it would have made a cool youtube clip as i was wearing a go pro
Old 12-03-12, 06:09 PM   #4
Red Herring
Or made the crash investigation and coroners report a whole lot easier....
Old 12-03-12, 06:17 PM   #5
ian505050
Always doing my best to save the country money. Time wasted is money wasted.
Old 12-03-12, 06:18 PM   #6
Red Herring
You certainly got full value out of the tyre.....
Old 12-03-12, 06:23 PM   #7
ian505050
Not true, garage said there was at least 5 miles left when i pulled up.
New tyre photo just to prove i am not a complete idiot.
Michelin have a deal with most garages this month that they pay for fitting and on some tyres even give you £25 cash back if you send them a copy of the receipt
Old 12-03-12, 06:31 PM   #8
sv4me
sv4me's Avatar
You can't see the belts all the way round on the old one, what are you made of money?
Old 12-03-12, 06:35 PM   #9
ian505050
need to be paying £206 for a set of the above. I recon my fuel cost to tyre ratio cost is gonna be quite close this year.
What would the law have to say about the tyre if i got pulled?
Old 12-03-12, 06:42 PM   #10
Runako
Its not proper worn out until the sparks are flying off the belt
How good is this weather? mister c Idle Banter 40 03-12-11 08:09 PM
Weather Look Good on Sunday..... crewmanchris Thames Valley 7 05-04-09 07:04 AM
Weather forecast for Sunday Dicky Ticker The Essex Lounge 1 30-07-06 07:34 PM
Sunday 5th weather dependent alternative Dicky Ticker The Essex Lounge 0 04-06-05 07:33 PM
Weather for Sunday...... Jabba 2005 Annual Rideout 9 02-06-05 12:35 PM
