Old 13-03-12, 05:02 PM   #1
hardhat_harry
Default Another rebuild
Another SV engine rebuild in my dustsealed lab.
Old 13-03-12, 06:17 PM   #2
suzukigt380paul
Default Re: Another rebuild
what is it with you sv owners and engine rebuids/replacements,either the sv engine is a very unreliable and not long lasting,or you lot dont ever top up the oil or change it,i know i run what can only be described as a fleet of bikes but my old b6 has 54k on the clocks and the engine has never been touched,and much the same story with the other bikes,apart from 2 strokes the last engine i rebuilt was a honda cb750 f1 1975 vintage and that was when i put the drive chain through the crankcases when the horse shoe link came apart, and some 100k or more later i have never had a engine letgo
Old 13-03-12, 07:56 PM   #3
hardhat_harry
Ah I got this engine cheap too but front cylinder knocking, not too much, I have my fingers crossed its just shells.
99% of the time its certain folks not topping their oil up that causes SV engines to go pop.
There are plenty high mileage SV engines about.
I find fiddling with engines theraputic too
Old 13-03-12, 08:02 PM   #4
Thats because you never exceed 50mph Grandad
Old 13-03-12, 08:26 PM   #5
suzukigt380paul
your getting confused with jordan
Old 13-03-12, 08:30 PM   #6
Harry
Your making the Shed of Doom (YC's) look tame now!!
Old 13-03-12, 09:12 PM   #7
muzikill
muzikill's Avatar
Well if the gearbox dogs didnt have metal fatigue I wouldnt have needed to do mine. Some of us keep an eye on the level of the liquids in our machines
Old 13-03-12, 09:14 PM   #8
muzikill
muzikill's Avatar
There too much bagging and tagging going on there lol.
Old 13-03-12, 09:59 PM   #9
hardhat_harry
Split the cases tonight and crap another knackered crank
Old 14-03-12, 05:32 PM   #10
Ha Ha I thought you'd caught the same disease
My RGV 250 Rebuild danf1234 Photos 44 11-05-13 08:01 PM
help with caliper rebuild?? arcdef Thames Valley 3 04-01-09 05:36 PM
caliper rebuild sv_rory SV Talk, Tuning & Tweaking 42 14-12-08 12:40 AM
Rebuild. John 675 SV Talk, Tuning & Tweaking 15 26-08-08 06:22 PM
The rebuild!! Jester666 Soho Massive 2 20-05-07 12:22 PM
