Old 13-03-12, 08:46 PM   #1
Springbokki
Talking Shoei helmet noise?
Mode please move if required.
Anyone got a Shoe Qwest?
Anyway of making it quieter?
And yup, wear earplugs the majority of the time.
Old 13-03-12, 08:59 PM   #2
arcdef
Default Re: Shoei helmet noise
buy one of the whisper strips, ive got one on my xr 1100 and it works wonders
Old 13-03-12, 09:27 PM   #3
Springbokki
Whisper strips?
Old 13-03-12, 09:27 PM   #4
Jackie_Black
Put the chin thing in the bottom, its completely unusable without it and should never been put on the market. Mine whistles and howl horribly without it, but it does look nice. Can't use it with a foggy now either as it pretty much lets no air in with the chin thingy in, so it steams up.
Old 14-03-12, 11:37 AM   #5
HoL
Default Re: Shoei helmet noise?
I can't believe you think it's noisy, when I swapped from my awful old helmet to a Qwest I could barely hear the engine. Do you keep the chin curtain on? might make a bit of a difference
Old 14-03-12, 11:48 AM   #6
Nobbylad
Nobbylad's Avatar
You can buy a whisper kit as mentioned above, which has a chin guard (mesh) as well as a soft 'curtain' that clips in around the base of the helmet.
It's essentially a soft, cushioned piece of material around 2 inches wide.
Hopefully you can see the image?
Old 14-03-12, 11:49 AM   #7
Nobbylad
Nobbylad's Avatar
http://www.shoei-europe.com/uk/products/accessories/
Old 14-03-12, 04:00 PM   #8
embee
embee's Avatar
Also check that the visor is sealing against the seal all round. Someone else had this issue, and after discussion it turned out it wasn't quite sealing. The side pods where the visor fits have spring loaded slider jobbies in them and these are adjustable.
Also check the lever on the left side isn't set to "city" position (or whatever they call it), where it cracks the visor open a touch. I'd certainly rate the Qwest as one of the quieter helmets around.
Old 14-03-12, 09:22 PM   #9
sniff
sniff's Avatar
I've got XR1100 and is by far the nosest lids I've ever owned. The visor needs to be adjusted the wind noise getting under chin bit is a joke. Yes you can get the wind skirt but you end up with misted up visor.
Easy answer is get a Shark Race R. Fantastic lid at the moment I cant find any real faults on it. Apart from the dark visor is £75
sniff is offline   Reply With Quote
Old 15-03-12, 07:10 AM   #10
Jackie_Black
I had an XR1000 before the qwest and the qwest is noisier without the chin curtain! I'm going to try an Arai next.
Wind noise on my Shoei sniff Helmets 5 09-09-11 05:44 PM
Shoei helmet used the white rabbit For Sale - Other Bikes and General biking items 4 18-07-11 04:56 PM
Shoei Helmet Shoei XR1000 Symbol TC2 - Blue MarcusHobley For Sale - Other Bikes and General biking items 1 08-12-10 10:17 PM
Shoei helmet doe Bikes - Talk & Issues 13 08-05-06 11:52 AM
Shark, Shoei or AGV helmet? Moose Helmets 10 24-03-05 08:48 AM
