Old 16-03-12, 02:55 PM   #1
rob650
Default Curvy clocks not working right.
Hi All,
Just joined so HELLO!
I brought an SV650sy 'v' reg, all was good on the test run, and I rode it for a few days after delivery, however yesterday I noticed that the rev counter, speedo, netural light and hi/low beam indicator on the dash are not working. Turn signal indicator blinks as it should and the dials are lighting up when the headlight is on.
Can anyone shed any light on whats happened?
Rob
Old 16-03-12, 03:40 PM   #2
Owenski
Default Re: New bike - New problems
I would hazard a guess the blubs which make up the back lighting on your dash have blown.
Easy fix, with a little strip down swap the bulbs and rebuild good-to-go
EDIT: Hello and welcome,
hang about and someone may be able to point you in the right direction for the replacements.
Old 16-03-12, 03:52 PM   #3
TamSV
TamSV's Avatar
Should have gone to Specsavers mate
Could be a dodgy connection to the clocks maybe? Check the wiring and connectors for any damage/corrosion.
Old 16-03-12, 03:55 PM   #4
Before going any further check fuse 5 marked 'meter'.
Old 16-03-12, 04:01 PM   #5
TamSV
TamSV's Avatar
Try the easy thing first eh? It'll never catch on.
I hadn't even realised the clocks had their own fuse TBH. Every day's a school day on here.
Old 16-03-12, 04:19 PM   #6
Owenski
Even read it a few times over after reading your post and still didnt understand it.
Went from "thinkin bulbs dont work"
to "bulbs never work when lights are switched off, wtf is he on about"
to "finally I understand the problem". but still no idea how to sort it, but Sid is here anyway so OP will be fine
Old 16-03-12, 05:15 PM   #7
rob650
Spot-on - Connection block behind dash
Cheers Guys - Thanks
HELP! Please. Clocks not working correctly. cbay SV Talk, Tuning & Tweaking 8 08-03-11 04:37 PM
Clocks not working - K6 trackbike. antony SV Talk, Tuning & Tweaking 0 14-07-10 06:32 PM
clocks not working k3 pointy baldricc SV Talk, Tuning & Tweaking 1 04-06-10 02:18 PM
My Speedometer/clocks stopped working. Girth SV Talk, Tuning & Tweaking 3 10-06-08 07:46 PM
Still wanted, curvy naked model clocks, any working condition northwind Stuff Wanted 7 26-01-08 04:24 PM
