I picked up my bike last night from my mates garage to take it home and only just noticed that i have no illumination in the clocks.
All dashboard indicator lights work, headlights, indys etc, just the clock illumination. Could ALL the illumination bulbs have gone or is there a fuse in the fuse box that could explain this? Cheers Chris |
Wiring diagram online looks like a Grey wire could be the culprit in the main clock harness, will investigate tonight.
If that's ok then its the bulbs I reckon ![]() |
Would be my guess
Sent from my PC NOT using any Tapatalk type rubbish!! █╬╬╬╬(•)i¯i▀▀▀▀▀█Ξ███████████████████████████████) |
if all the lights are working cant be a fuse probs a loose wire.
looking at the wiring diagram it looks as you said the grey wire unless its the earth.
by the way chris fitted another left switchgear now got choke n pass working thanks again for your help sunday darrell |
had the same on my 2000 model and it was bulbs got ten bulbs from ebay they are T4 bulbs , only one bulb had blown so they must be on a curcuit of there own ony cost a couple o quid , you have to take the back of the clocks and take the curcuit board out to get at the bulbs which are a push in fit
I wouldn't rule out bulbs - normally nothing gets done until the last of them has failed - Occam's razor.
If a fuse had popped some other stuff wouldn't work as well.
#9 | |||
#10 |
All three bulbs had blown, managed to replace one with a spare that I had in another set of clocks but need more
Are these the right bulbs I need? http://www.ebay.co.uk/itm/10-x-Clear...item3cc01f89be |
curvy clock repair | martin15s | SV Talk, Tuning & Tweaking | 0 | 24-04-11 01:18 PM |
Clock illumination colouring? | rekab74 | SV Talk, Tuning & Tweaking | 3 | 17-05-10 08:13 PM |
clock lights curvy | Nicky S | SV Talk, Tuning & Tweaking | 10 | 02-10-08 05:37 PM |
Digital clock on a curvy? | shelleyamy | SV Talk, Tuning & Tweaking | 16 | 21-05-08 07:46 PM |
Would you buy a TL1000S with 52k on the clock for 2000 quid? | Wideboy | Bikes - Talk & Issues | 21 | 15-05-08 11:41 PM |
