29-03-12, 12:03 PM | #1 |
Datatool alarm help needed.
Hello!
I need your help, urgently! I've got a K3 sv650s with a datatool alarm. I've been having some battery problems and I've taken the battery off the bike and had it on charge. I've come to re-fit it today, no problems so far. Turn the ignition on to start it up and nothing, battery is completely dead. So disconnect the battery again and the alarm starts chirping even though the battery isn't connected. The question is how do I stop it chirping?! The fob doesn't seem to be doing anything when I press it and when I tried to connect the battery again the alarm started screaming away. However whilst typing this the alarm has stopped chirping. Does anyone have any ideas as to why it is doing this and is it going to start chirping again if I don't do anything else? Thanks in advance. |
29-03-12, 02:36 PM | #2 |
Re: Alarm Help needed!
You didn't say what model alarm.
It's probably that the alarm has a tiny bit of charge in the internal battery. By connecting the main battery (presumably it has a little charge in it at least) you have caused the alarm to go off. If its regular chirping it would suggest you put it in service mode before you removed the battery. Once you have a good battery on the bike again let us know what happens. If it's an older datatool you might have to de-spike it. |
29-03-12, 02:39 PM | #3 |
It almost definitely won't start chirping again. The internal battery has probably run out now. Every time you connect a battery though it'll take a little juice from it.
Have a look at the Dataool website. It had pretty much everything you need to know. |
30-03-12, 10:58 AM | #4 |
Re: Datatool alarm help needed.
I have a C4 Red Alarm by Datatool, the Fob has two buttons on it and to put the alarm into service mode is simple.
Switch on the ignition. press and hold both buttons on the key fob at the same time. hold for ten seconds. The Alarm will chirp to let you know it is ready. Switch off ignition. I can then remove the battery. It is well worth checking your fuse box too, some times depending on the model there is enough residual current that you may need to remove the fuse to prevent damage. I do not have to do this, but I have heard of some who do. Good luck.
My bar swap and custom suspension Buy my latest novel and help fund my addiction to strippers and Lego. Last edited by Jayneflakes; 30-03-12 at 11:00 AM. |
03-04-12, 06:38 PM | #5 |
sorry for the lake of response, I'd had exams last week. anyway it's all sorted now with a new battery
Thanks for the replies ;D |
04-04-12, 03:57 PM | #6 |
mines just come back from the stealer with the same problem, battery was dead, went to move bike, alarm went off couldnt shut the f-ing thing up! after 2 hours i called streetbike to come get it lol was just a flat battery so they charged it up and removed £60 from my bank account lol
Datatool alarm | allantheboss | Bikes - Talk & Issues | 15 | 12-02-10 10:41 AM |
Datatool alarm | nickodemon | SV Talk, Tuning & Tweaking | 20 | 03-01-10 09:44 PM |
Datatool Alarm HELP please | gowiththeflow75 | Bikes - Talk & Issues | 0 | 04-06-09 07:02 AM |
Datatool S4 Alarm | COLZO | Bikes - Talk & Issues | 3 | 13-03-09 12:40 PM |
Datatool 3 alarm help ... | sprocket | SV Talk, Tuning & Tweaking | 20 | 29-11-05 05:01 PM |
