Old 01-04-12, 06:37 PM   #1
Default Pointy maximum temperature?
At what temperature do bad things start happening to the engine? It's a K3
My fan came on at 106 today but it continued to rise up to 114
Old 01-04-12, 07:23 PM   #2
muzikill
muzikill's Avatar
Im sure anything just over the 100 mark is about right for it coming on, not sure about the 114. Its supposed to cool it down!
Old 01-04-12, 07:25 PM   #3
AmigaNut
Default Re: Maximum temperature?
Mine kicks in at 104 and drops to 97, its a K7 naked 650.
AmigaNut
Old 02-04-12, 06:55 AM   #4
Kenzie
Kenzie's Avatar
Default Re: Pointy maximum temperature?
Suzuki tech said it's supposed to kick in at 102c (K7 Pointy)
Old 02-04-12, 09:13 AM   #5
muzikill
muzikill's Avatar
If you haven't 'mucked around' with the cooling circuit in any way and it's going to 114 then its time to get the manual out and test the components in sequence.
Old 02-04-12, 09:13 AM   #6
flymo
flymo's Avatar
AmigaNut
About the same on my SV1000. Was out on a warm day yesterday, fairly stationary in the Wirral egg run with little airflow over the engine/rad.
Temperature rose to around 105/106 and then cooled, presumably with the onboard fan to around 95/97. When I managed to pick up a little speed (around 30mph or so) the temp drops to around 89 and remains fairly static.
I would be a little concerned if your temperature is going much above those sorts of figures, perhaps your thermostat driving the fan could do with replacing.
Old 02-04-12, 09:29 AM   #7
The Guru
Originally Posted by Suzuki SV650/S Service Manual
Cooling fan thermo-switch operating temperature
Standard
(OFF > ON): Approx. 98c (208f)
(ON > OFF: Approx. 92c (198f)
Taken from service manual
Old 02-04-12, 11:20 AM   #8
larssonn
Mines a K3 and my temp never goes higher than about 94C then goes down about 80 something.
Old 02-04-12, 12:31 PM   #9
mine hovers around 76-78c and on very hot days will rise to 90-92c fan kicks in around 100c.
Daz if your bike is slow at reaching its operating temp (i'm around 1/2 mile) then it might be a good idea to get a new stat.
i let the bike idle till it starts showing its temp at about 23c then off i go and within 1/2 mile i'm up to temp which is 76-78 which it will sit steady at till i come to a halt at lights.
Old 02-04-12, 02:15 PM   #10
mpsricky
agreed!!
i dropped mine in for service on friday past, suzuki mechanic said they usually come on 104°C +/-few °C. (K6 pointy)
Which security devices offers maximum discount on insurance? badsaboy Bikes - Talk & Issues 20 11-05-11 09:11 AM
Maximum Width for rear tyre? BomBalong SV Talk, Tuning & Tweaking 10 03-04-10 11:55 AM
Crash.NET - Confident Pedrosa 'pushes to the maximum' NewsBot News 0 28-08-09 11:20 PM
Maximum Working Temperature Tara Idle Banter 25 20-07-06 11:24 AM
maximum to drop fork through yokes Dennis SV Talk, Tuning & Tweaking 1 16-12-05 10:15 AM
