Old 03-04-12, 09:45 AM   #1
Macpauley
Default Random headlight problem.
Been having a fault with the main headlights on my curvy, one side stopped working, then both, then they were both fine, then one stopped & now today both have gone. Clocks, indicators, parking light & Hi-beam are all fine....
I've had a look under the seat & can't see any wires rubbing & cleaned the connectors on the the back of the lights.
Is there something I'm missing?
I'm going to replace the bulbs, are these worth a go?
Old 03-04-12, 10:12 AM   #2
NTECUK
NTECUK's Avatar
Default Re: Random headlight problem
Bulbs often mess about when the filaments are old and get knocked about.
Dint recognise the make .
Philips super brilliance are v good .
Work colouge has these in ther Nissan
http://www.auto-essentials.co.uk/eco...air-p-214.html
Old 03-04-12, 10:32 AM   #3
Luckypants
Luckypants's Avatar
Never heard of them but at £7 odd a pair I'm pretty certain they will be poor quality. Anything that relies on a coloured filter to give them 'brilliance' are crap IMO, as a filter does one thing only, reduces the amount of light allowed out of the bulb and so reduces light on the road.
Get some quality uprated CLEAR bulbs, such as OSRAM Nightbreakers or Phillips X-tremes to see a difference.
Not sure that changing the bulbs will solve your intermittent problem, it sounds more like a wiring fault than the bulbs.
Old 03-04-12, 05:02 PM   #4
Macpauley
Cheers for that I'll bin those ones, just took the side off & found this....
ermmmmm!
Old 03-04-12, 10:52 PM   #5
NTECUK
NTECUK's Avatar
Default Re: Random headlight problem.
Nice colours
Know the person who did that
Old 04-04-12, 01:07 PM   #6
monkey
Reckon there's been a dodgy connector in that plug (earth tape) as it looks like its been bypassed.
It might be worth having a gander to check the others.
Old 04-04-12, 01:32 PM   #7
jambo
jambo's Avatar
There are 2 block connectors, one either side of the centre fairing (take both side panels off).
From memory one of green and one yellow. The wiring for the headlights run through these, and a corroded block, or dodgy wire going into the block can cause these symptoms.
Though as you've found one to have been bodged heavily that'd be where I'd start
Jambo
Old 05-04-12, 08:43 AM   #8
Macpauley
Bingo!
Had the sides off again, one block was rusty & cracked, new one in and I had one light working for about 5 mins then nothing.... got out the multimeter, power & circuits are fine so out came the bulbs & both are gone. Quick trip to the car shop & new bulbs are working fine, dunno for how long though.... time to start looking for a new loom me thinks!
Headlight Problem BomBalong SV Talk, Tuning & Tweaking 12 19-04-11 08:16 PM
Headlight problem on low beam jono878 SV Talk, Tuning & Tweaking 12 21-10-10 06:57 PM
headlight problem matt_rufus SV Talk, Tuning & Tweaking 5 25-05-09 09:18 AM
Headlight problem. svdemon SV Talk, Tuning & Tweaking 4 07-08-07 09:17 PM
Random Post about Random Stuff tricky Idle Banter 14 13-02-06 08:03 PM
