Old 03-04-12, 07:21 PM   #1
m1tch_1987
Default Weight of ancillaries?
Hi all,
I am still working on my SV650 kart project, I am getting to the stage of working out the balance of the kart with the engine being on 1 side and myself in the middle there will be an inbalance, I can shift the seat over to offset this, however I am thinking about partly offsetting the engine weight on the right with the ancillaries on the left ie:
Battery
Radiator/coolent system
Fuel tank
Wiring
I am just wondering how much the items usually weigh so I can work out the balance of the kart, usually the fuel tank on the kart is under the steering wheel, but I might move it over so that it can offset the weight slightly but as I physically don't have the parts I was just wondering how much they weigh usually
Old 03-04-12, 08:57 PM   #2
embee
embee's Avatar
Default Re: Weight of ancillaries
Just a ballpark
Battery - Yuasa YTZ-10S = 3.2kg
Coolant - total capacity will be maybe 3Lt, say half in engine half in rad&hoses, density isn't far off 1kg/Lt, rad doesn't weigh much empty, 1 or 2kg.
Fuel - density about 0.75kg/Lt, fuel tank not a huge mass empty (depends what you're using, but maybe around 5kg max). Unless you're doing endurance work you'll only be carrying a few Lts I'd guess.
Wiring - if you're only running the essentials (ignition etc) it'll be trivial, 1 or 2kg tops.
The driver will be the most useful mass to move, 70+kg
Old 04-04-12, 12:58 PM   #3
m1tch_1987
Default Re: Weight of ancillaries?
Cool, thanks for clearing that up, ive never had a bike before so im never too sure about how much certain parts weigh like the battery (used to larger car batteries lol)
Wanted: Rear brake lever & other ancillaries for '02 sv650s killbot87 Stuff Wanted 5 14-03-10 09:24 PM
How much weight?? dizzyblonde Bikes - Talk & Issues 8 18-02-08 12:06 AM
Anyone else here trying to put on weight? rubberduckofdeath Idle Banter 143 30-10-07 05:19 PM
What weight oil do you use? andyb SV Talk, Tuning & Tweaking 23 24-06-07 02:27 PM
Weight mpaton2004 SV Talk, Tuning & Tweaking 30 18-01-05 10:15 AM
