Old 11-04-12, 08:54 PM   #1
XmisterIS
Default Beowulf Exhaust backfires, bad for my bike?
I have fitted a Beowulf slip-on.
Now that it's bedded in, it sounds really lovely, especially with the db killer removed!
In particular, it can produce some pretty impressive backfires - complete with flames.
BUT - is that damaging my engine in any way? The sound and the backfires and gurgling is very nice, but I don't want to damage the engine.
Old 11-04-12, 09:05 PM   #2
Noddy
Default Re: Beowulf Exhaust backfires
If it's anything like my Delkevic stubby, it pops and bangs like a goodun on the over run. I believe it's quite normal. I'm pretty sure somebody more knowledgeable will be along shortly to give a better explanation. It does sound pretty epic though doesn't it.
Old 11-04-12, 09:11 PM   #3
i have a k7 twin spark with a warrior fitted and i don't get backfiring, flames or popping.
Old 11-04-12, 09:11 PM   #4
NTECUK
NTECUK's Avatar
You should fit a PC as its not so good having unburned fuel washing the bore of oil,Lean Mixtures often backfire
You Tried a Performance filter as they sometimes counter act each other ?
Old 11-04-12, 09:13 PM   #5
rictus01
rictus01's Avatar
if a can was the only change you made and was fitted correctly, then you shouldn't have excessive back firing or flames, I suspect you haven't sealed it very well
However, it's unlikely (but no promises) to damage the engine, but if your can is a race one and has packing in it, this will be stripped out far quicker, leaving the skin (especially if it's carbon) susceptible to heat damage or distortion.
Cheers Mark.
Old 11-04-12, 09:28 PM   #6
Noddy
So, mine being a curvy could be running a little on the lean side. It generally pops and bangs when rolling off after quick burst of acceleration? If I'm being a bit more conservative with the throttle it doesn't do it anywhere near as much.
Old 11-04-12, 09:30 PM   #7
NTECUK
NTECUK's Avatar
Richen the idle up a touch.Mind you the carb,s ant easy to get too
Old 12-04-12, 12:45 AM   #8
Joe Marcon
Default Re: Beowulf Exhaust backfires, bad for my bike?
Its fine for the engine . I rev alot and hit kill switch on and off very fast and it sounds like a bomb exploded . I did this 100 times on my birthday . And a few other times and nothing has happened lol . Give it ago . U wont stop doing it .its funny watching people jump lol
Old 12-04-12, 07:50 AM   #9
HoL
Were you 100 years old?
Old 12-04-12, 08:11 AM   #10
tom-k6
i think the only way it could damage is if it backfired back through the cabrs/airbox. its unlikely but im sure some people on here have had it happen, but no mention of damage.
flames look cool dont they
Beowulf exhaust decal - where from? cringer Bikes - Talk & Issues 3 30-08-10 02:23 PM
Gel seat and Beowulf warrior exhaust MrFish For Sale - SV's and SV related items 12 20-06-10 06:40 PM
Curvy Beowulf Exhaust 5hort5 Stuff Wanted 0 10-03-10 12:27 AM
Just bought a beowulf studdy oval exhaust :) ... how do I fit it? Paul the 6th SV Talk, Tuning & Tweaking 8 09-06-08 04:34 PM
New Exhaust and Backfires M65 SV Talk, Tuning & Tweaking 24 18-10-04 09:50 PM
