Old 18-04-12, 09:45 AM   #1
deltron
Default Chain master link pin flairing question
I'm struggling to flair the master link pins on my new Tsubaki Sigma O-ring chain. I specifically bought a reasonably heavy duty chain tool to do the job but I just can't seem to get enough purchase on it to make more than a small indentation on the pins:
The master link seems fairly solid as it won't budge when attacked with a pair of pliers, however I don't feel confident to ride the bike when the pins aren't really flaired at all.
Am I doing it wrong?
Old 18-04-12, 10:04 AM   #2
MJC-DEV
MJC-DEV's Avatar
Default Re: Chain master link pin flairing question
Wrong sort of rivet link for that tool. You need a hollow end rivet link. The ones you have are solid pins.
http://static.bandcexpress.co.uk/med...-links_1_1.jpg
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers
MJC-DEV is offline   Reply With Quote
Old 18-04-12, 10:28 AM   #3
There are two types of rivet link and two types of tool:
Links:
1. Plain ended, such the the pins are a solid cylinder.
2. Recessed, such that the ends of the pins are hollow cylinder 2-3mm deep.
Tools:
1. Hammer staking tool - typically known as 'Whale'
2. Clamp type press tool - the one you've got.
The pin is of the former type, the tool is of the latter - that won't work.
Old 18-04-12, 10:41 AM   #4
deltron
Thanks guys - lesson learned
So just to confirm, if I buy one of these master links then I'll be able to flair it with the tool I have?
Old 18-04-12, 10:54 AM   #5
MJC-DEV
MJC-DEV's Avatar
Yep
Old 18-04-12, 06:25 PM   #6
Try to find a link that's the same brand and type as the chain - not all manufacturers use exactly the same dimensions for the pins etc.
chain link tool 01 sv650s Stuff Wanted 0 22-03-09 05:41 PM
blue link in chain kwak zzr Bikes - Talk & Issues 13 10-08-08 09:06 PM
Clip type master link yorkie_chris SV Talk, Tuning & Tweaking 20 08-11-07 06:02 PM
chain link steveg SV Talk, Tuning & Tweaking 3 30-04-07 08:13 PM
Will stiff chain link cause chain noise dclifford SV Talk, Tuning & Tweaking 8 16-08-05 11:56 AM
