Old 23-04-12, 12:25 PM   #1
muzikill
muzikill's Avatar
Default Extending the throttle vacum pipes, Pointy?
Can someone post me a few links on doing this on a 650s k3? Im searching all over the place trying to locate the info to make it easier the balance the bodies in the future.
Thanks in advance.
Old 23-04-12, 12:29 PM   #2
Default Re: Extending the throttle vacum pipes
hahahahaaaaaa. plonker
i have a kit for doing just that
i'll post one out sometime in the next cppl days m8.
Old 23-04-12, 02:26 PM   #3
muzikill
muzikill's Avatar
I know, i know ..... keep a hold of the carbtune until i fit it pretty please?
Old 23-04-12, 03:19 PM   #4
not a problem. its me spare anyway
Race Header pipes for pointy (m4 leo etc) Apache664 Stuff Wanted 0 14-02-11 06:15 PM
Pointy fuel tank breather pipes. curlylee SV Talk, Tuning & Tweaking 2 14-08-10 11:10 AM
pointy can and pipes markmoto For Sale - SV's and SV related items 5 30-04-09 07:00 PM
Twin rear pipes for the Pointy. danf1234 SV Talk, Tuning & Tweaking 17 29-06-07 06:19 PM
Borrow vacum gauges to balance carbs MarkP Guildford Massive 1 05-05-06 02:34 PM
