25-04-12, 11:28 PM | #1 |
Spacer dimensions for emulators in Pointy fork please
Itching to swap in Debrix Em's but gonna try and get the Spacers machined locally. Can anyone give me the precise dimensions for the spacer?
Also, how much should I bore out Damper Rod? This is for the Pointy install. Thanks Ronnie |
26-04-12, 12:02 AM | #2 |
Re: Emulator Spacer Dimensions Please
26-04-12, 09:43 AM | #3 |
Re: Spacer dimensions for emulators in Pointy fork please
Yeah, I'm actually all over this thread but didn't remember UF posting the dimensions etc. Will have a better look. Cheers Bibio
26-04-12, 10:16 AM | #4 |
To assist, if anyone else is looking:
Emu measurements - 27.0mm OD; 23.95mm ID; 7.5mm long (I presume 'OD' is Outer Diameter and 'ID' is Inner Diameter. Please correct me if I'm wrong); Damper Rod measurments - 4x8mm holes @ bottom of damper rod; Drill out to 11mm (Allows Emu to provide damping); Deburr*; Block off 1.8mm diameter rebound hole (top of the damper). * I didn't really know how to do this but this article explains it. A special tool is probably needed. Check out your local DIY store. Last edited by Runako; 26-04-12 at 10:17 AM. |
26-04-12, 10:34 AM | #5 | |
but it can be done with a small rounded hand file, although a little awkward. |
26-04-12, 10:43 AM | #6 |
your only taking off the ragged edge if there is any so a bit of wet'n'dry or emery cloth will be just fine. you don't need to go to the expense of a de-burr tool for 1 use.
99-00 fork dimensions? | runrun | SV Talk, Tuning & Tweaking | 0 | 06-12-11 07:13 PM |
K3 fork spacer length? | RingDing | SV Talk, Tuning & Tweaking | 0 | 30-05-11 10:53 AM |
Ohlins fork spring spacer | SVDragRacer | SV Talk, Tuning & Tweaking | 13 | 17-05-10 07:17 PM |
k5 fork spacer length? | fast-lad | SV Talk, Tuning & Tweaking | 1 | 02-06-09 04:42 PM |
Racetech emulators - what fork oil? | skov | SV Talk, Tuning & Tweaking | 0 | 27-05-08 10:36 AM |
