Old 02-05-12, 04:02 PM   #1
Thaleshwar
Default Lubricating Chain Grease VS Oil?
Hi,
A daft question what is best to lubricate motorcycle chain with - Grease or Oil?
Thanks.
Old 02-05-12, 05:46 PM   #2
-Ralph-
Default Re: Lubricating Chain Grease VS Oil
'I can't believe it's not butter' works a treat mate...
Old 02-05-12, 06:33 PM   #3
Originally Posted by Thaleshwar View Post
Hi,
Thanks.
Neither, unless you're using a scott oiler, which uses oil, but on a limited drip feed. You could paint oil onto the chain, but it would get flung off real quick
Chain wax or chain lube is what you need.
Halfrauds sell Castrol chain wax, which I've found to be good, lasts well and doesn't fling off.
Otherws will have their own preference
Chain grease question warrenhewitt10 SV Talk, Tuning & Tweaking 15 17-06-10 02:20 PM
Lithium grease / Castrol red rubber grease DarrenSV650S Bikes - Talk & Issues 25 22-01-10 09:59 AM
Would you like those lubricating sir? RhythmJunkie Idle Banter 1 23-07-07 09:39 PM
Lubricating the calliper pistons Balky001 SV Talk, Tuning & Tweaking 25 01-03-06 02:45 PM
Oiling / Lubricating the cables Thaleshwar SV Talk, Tuning & Tweaking 7 28-02-06 10:08 AM
