Old 13-05-12, 06:21 PM   #1
SV..al
Default SRAD fork internals in Pointy forks?
Iv'e done a search and read quite a bit about fork swaps but have not found an answer to my question which is simply can i fit srad 600 rwu fork internals into my K3 lowers? Any advice appreciated .
Al
Old 13-05-12, 06:24 PM   #2
Default Re: Srad forks
Yes you can do it, no you can't "simply" do it.
Old 13-05-12, 06:37 PM   #3
SV..al
Cheers mate....enlighten me please as to why not simply? Is it a big job? Iv'e stripped the forks and done the seals but the left one just keeps ripping the new seal due to pitting in the fork travel area. Thought about a new stanchion but i would rather replace with better internals.
Al
Old 13-05-12, 06:41 PM   #4
Well that bit isn't really "internal" for a start
And the SRAD ones are a good few mm fatter than the SV ones!
Just use entire SRAD front end
Old 13-05-12, 06:48 PM   #5
SV..al
When i did the seals i gave them a full internal and took everything out cleaned it all and put them back together with fresh oil. If i fit the srad front end do i basically need everything off the srad...wheel,mudguard,top/bottom yokes,calipers and clip-ons? and what about the speedo pick-up does that have to be done from the back wheel?
Al
Old 13-05-12, 06:49 PM   #6
Yes everything. Think you can use VTR clipons or custom ones if you want higher.
Old 13-05-12, 07:27 PM   #7
SV..al
Would turn out an expensive mod then....probably worth it though. Thanks for your advice YC.
Al
Old 13-05-12, 07:36 PM   #8
Sell your existing stuff and it's not too bad
Old 13-05-12, 08:55 PM   #9
SV..al
Default Re: SRAD fork internals in Pointy forks?
How about putting in zzr600e internals? Is it just a case of taking everything out of the forks and putting it in the sv lowers or does anything need to be machined or cut down?
Al
Old 13-05-12, 09:02 PM   #10
Is this a game of name random bike front ends and see if YC is enough of a sad tw*t to know how to frankenstein them into an SV? (No smarmy comments please, I have long since resigned myself to the answer to this question...)
Not sure about ZZR600E, thought they had 43mm fork.
CBR600F3 fork internals in SV forks? sixstring SV Talk, Tuning & Tweaking 28 11-04-11 08:44 PM
Pointy fork springs fit GSXR forks? SVMAT Bikes - Talk & Issues 14 18-02-11 08:25 PM
What is stock fork oil for GSXR 750 SRAD forks? TamSV Bikes - Talk & Issues 21 08-01-11 12:37 PM
Fork tube for K5 Pointy (or complete set of forks) mikerj Stuff Wanted 0 30-07-10 10:21 AM
SRAD 750 forks and yokes. SRAD calipers. yorkie_chris For Sale - Other Bikes and General biking items 49 23-01-10 08:06 PM
