Old 14-05-12, 09:18 AM   #1
twowheels
Default Front Master Cylinders 1000 vs 650?
hello! does anybody know if the front MCC front he SV is the same part as the 1000?
Thanks!
Old 14-05-12, 11:25 AM   #2
Default Re: Front Master Cylinders 1000 vs 650
All Pointy are the same, Curvy isn't identical part number but has the same piston etc, so in function it's identical.
Naked is same cylinder/piston etc, obviously it has the reservoir built in but it works the same.
Old 14-05-12, 12:34 PM   #3
twowheels
Default Re: Front Master Cylinders 1000 vs 650?
Thanks buddy, as long as the 1000 mastercylinder is the same part as the 650 ill just use that, probably the faired model as i have lots of spares for it. thanks
Master Cylinders upgrading danf1234 SV Talk, Tuning & Tweaking 2 10-07-11 07:59 PM
Identify these master cylinders! TOLAROS SV Talk, Tuning & Tweaking 8 06-02-09 03:54 PM
master cylinders naked vs faired. Razor SV Talk, Tuning & Tweaking 14 15-04-08 01:25 PM
Pointy or Curvy, 650 or 1000 Naked SV Front Master Cylinder SoulKiss Stuff Wanted 0 19-03-08 06:30 PM
Rear brake master cylinders? svrash SV Talk, Tuning & Tweaking 2 16-10-06 11:04 PM
