Old 14-05-12, 05:05 PM   #1
Dave_es94
Default How do i remove check oil light sv650 K6?
How do i remove the Check oil light on my SV650 SK6 model?
Old 14-05-12, 05:17 PM   #2
Default Re: How do i remove check oil light sv650 K6
It's not a 'check oil light'. The indicator does not warn of oil level, it indicates a low level of pressure, the oil pump is turned by the engine - engine not running = no oil pressure.
Oil level is checked by viewing the window on the side of the engine by your right toe. Check it often, then do it again some more.
Old 14-05-12, 05:19 PM   #3
Dave_es94
Default Re: How do i remove check oil light sv650 K6?
Thanks just found this out! The bike hasnt been running much as i gotta wait a little while till i have insurance money
Old 14-05-12, 05:20 PM   #4
rock the kill switch to 'run' or its an FI fault like a breather hose come loose.
Old 14-05-12, 05:26 PM   #5
is it in neutral?
Old 14-05-12, 09:06 PM   #6
Dave_es94
Its because the bike wasnt running and there was no oil pressure
SV650 K3 swing arm bearing replacement - remove exhaust? daffyduck1962 SV Talk, Tuning & Tweaking 4 29-04-12 03:32 PM
sv650 99-02 rear light+indicators+numberplate light andyrs For Sale - SV's and SV related items 3 29-09-06 10:59 AM
sv650 with gsxr 750 light extensive SV Talk, Tuning & Tweaking 0 10-03-06 02:43 AM
Oil or Check engine light is on wilsonma08 SV Talk, Tuning & Tweaking 0 16-08-05 06:00 AM
Coolant Temp Check Light kern0079 SV Talk, Tuning & Tweaking 3 01-03-05 05:20 PM
