Old 20-05-12, 03:54 PM   #1
craig dow
Default Where is neutral switch - Curvy?
hi when my sv650s 1999 stand is doen and bike is in nutural it wont start soon as side stand is up no problem , so think its the nutural sensor , havent got a clue where it is , or could it be something eles
thanks
Old 20-05-12, 08:45 PM   #2
Default Re: where is nutral switch
It's the black circular thing with four wires going to it below the front sprocket, behind the sprocket cover.
It will be covered in chain lube and goo and can therefore be difficult to see.
Old 21-05-12, 08:43 AM   #3
Default Re: Where is neutral switch - Curvy?
Does neutral light work?
Can be relay/connection too.
Old 21-05-12, 11:07 AM   #4
craig dow
yes the neutral light works fine
Old 21-05-12, 12:15 PM   #5
Then it is not switch, problem is in relay or connection to relay.
Personally I would just cut relay out of circuit entirely so only cutout is ignition switch and kill switch.
Old 21-05-12, 12:20 PM   #6
craig dow
ok thanks for that , there are two relays i think under the seat , whuch one will it be
thanks
Old 21-05-12, 09:08 PM   #7
There is one. It is combined neutral/sidestand relay and flasher. Other black box is fusebox.
You have wiring diagram to figure out which wires to connect?
Old 27-05-12, 01:26 PM   #8
craig dow
Default relay
im looking for a relay as side stand down bike wont start , and nutural light is on , and clutch in . so think it that ,as when stand up no problem at all the ones advertised on ebay says flasher relay , is that what i need , its a 1999 curv sv650s
thanks
Old 27-05-12, 06:09 PM   #9
Just bypass it
Old 27-05-12, 06:35 PM   #10
craig dow
what coulour wires as dont have diagram for it
Curvy switch gear Winder For Sale - SV's and SV related items 0 16-03-12 03:49 PM
1999 Neutral switch part number? neil.t.franklin SV Talk, Tuning & Tweaking 6 22-01-12 07:09 PM
Curvy RH switch gear Flash B Stuff Wanted 4 27-02-11 04:51 PM
Neutral Light for curvy ricky_t Bikes - Talk & Issues 0 15-03-10 03:38 AM
Neutral indicator light switch / ignitior retarder??? pipster SV Talk, Tuning & Tweaking 8 06-11-06 03:52 PM
