Old 23-05-12, 07:24 PM   #1
Default Curvy front end - what's inside the forks?
Righto
I'm needing to know the internals on a curvy front forks is set up.
Is it the outer Slider then the internal damping or is it all in the slide?
Thanks in advance
Old 23-05-12, 07:34 PM   #2
HoL
Default Re: Curvy front end guts whats inside
Does this help?
Old 23-05-12, 07:36 PM   #3
a load of crap, that's whats inside
Jelly mixed with blancmange, with curly wurly springs
Old 23-05-12, 07:38 PM   #4
I'm asking as I've been offered a new full set of internals that are meant to be off a Curvy SV for not a lot of reddies
Old 23-05-12, 07:40 PM   #5
Not a lot, how much...
Given that a fairly local suspension type will do you a set reworked on an exchange basis to fit emulators... What's the point?
What are you going to do with them? There's nothing worth doing...
Old 23-05-12, 07:41 PM   #6
£60
Old 23-05-12, 07:45 PM   #7
So again, what possible value are you going to get from them?
If you were capable of/going to mod them for emulators then you would be able to do it immediately while your forks were apart.
And that's f***ing expensive. I'll sell you a set for £59...
Old 23-05-12, 07:52 PM   #8
TBH I was on the hunt of a pair of new tubes as mine are a little bit battered
Old 23-05-12, 07:54 PM   #9
Well Andy, given that those bits are on the f***ing outside it's hardly likely someone is going to sell them (cheap...) described as internal is it.
If unsure, and this may be a mad mad suggestion, why not ask the seller?
Old 23-05-12, 08:02 PM   #10
Mate its full assemblies or the packet is marked as that. I was in picking something up in there. I was purely checking as the O/D was 37mm when we measured it
Wanting GSXR front forks to fit onto my sv650 curvy 2001 Joe Marcon Stuff Wanted 5 26-02-12 02:04 PM
GSXR front forks onto a Curvy mike_red2uk SV Talk, Tuning & Tweaking 12 21-03-09 03:57 PM
Curvy front forks! skapegoat Stuff Wanted 1 04-02-08 11:34 AM
GSXR 600 SRAD Front Forks, Yokes & Clipons for Curvy SV650 Conversion Ter For Sale - SV's and SV related items 3 19-07-07 07:38 AM
Curvy SV front forks WANTED! zunkus Stuff Wanted 7 18-02-06 12:31 PM
