Old 24-05-12, 05:28 PM   #1
muzikill
muzikill's Avatar
Default You know your wheels were misaligned when....
After a week of riding after doing it right the front tyres rubber on one side starts looking a different colour and takes a month of right hand corners to stop feeling twitchy when it starts to wear down. Misaligned rear wheels aint very safe!
sv wheels ,,bandit wheels rvracing Mini-Twins 2 19-05-10 07:28 PM
wheels dirtydog For Sale - SV's and SV related items 6 13-04-08 04:41 PM
Wheels for a K3 flymo Stuff Wanted 6 24-01-08 07:31 PM
wheels on the way. rictus01 Bikes - Talk & Issues 16 12-05-07 11:06 PM
4 wheels good, 2 wheels better Dysparunia Bikes - Talk & Issues 6 30-11-06 07:37 AM
